Date/Time: Wed, 26 Feb 2025 05:26:30 +0000
Candle formation dififfernce.
View Count: 433
[2021-05-10 15:43:37] |
MindPortal - Posts: 18 |
I just signed up for the denali data feed, my friend who I share an office with and referend me to sierra chart noticed that our volume candle formations are different using the same chartbook and service package. I paid for market depth, could that make a difference in the formation of the volume candles. or perhaps am I on a different server?
[2021-05-10 18:57:42] |
John - SC Support - Posts: 38172 |
If you are both using the Denali Exchange Data Feed, then as long as everything else about your charts are exactly the same, then you should not have differences in the volume. But, in terms of the charts being the same, they need to have at least the following the same: - Session Times - New Bar At Session Start - Load Weekend Data - Time Period Among other possibilities. In other words, there is a lot to check to ensure that the data is really the same or not. Refer to the following for additional information: Differences With Data and Chart Bars Between Services / Connections / Chart Types For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
