Date/Time: Wed, 26 Feb 2025 05:51:58 +0000
[User Discussion] - CQG Account value (NLV) incorrect
View Count: 538
[2021-05-07 23:57:13] |
User5044343 - Posts: 68 |
For the past few days a something is goofy with CQG ( not blaming Sierra here to be clear ). I tried reinstalling Sierra, and loading the latest pre-release version (2254) - same situation. I want to switch to direct routing once it becomes available. ----------------------------------------------------------- When a position is opened and it goes negative - the balance goes up ( it always went down ). When the position is closed, it goes to the correct amount. Very weird. I poll Sierra account balances every 5 seconds - so I have an external history of these values. I attached them for your enjoyment. Its as if someone at CQG flipped the -/+ signs on open positions. Anyone else have seen this happen? |
[2021-05-08 01:41:32] |
I tried reinstalling Sierra, Definitely do not do this. It does not help. I want to switch to direct routing once it becomes available. This is coming. Should not be much longer, we hope.
