Date/Time: Wed, 26 Feb 2025 05:33:20 +0000
Color background at price over multiple levels?
View Count: 515
[2021-05-07 20:24:38] |
j4ytr4der_ - Posts: 946 |
I suspect this can't (easily anyway) be done without ACSIL but thought I would ask anyway. Is there a way to color the background of more than just a single price level on a Numbers Bar, from a spreadsheet study? Color Background at Price of course only colors a single level. |
[2021-05-07 20:35:22] |
John - SC Support - Posts: 38172 |
With the spreadsheet, you can use the multiple columns to color multiple prices. Each column just has to have the level that you want to color. Otherwise, you would need to use multiple instances of whatever study you are using to color different levels (assuming you have a way to calculate it differently for the different levels). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-07 20:40:28] |
Yeah I would just rather not have to do multiple columns of formulas just for this.
[2021-05-08 00:50:26] |
Problem solved. Just use Dash as the draw style, and make it reasonably large in size. It doesn't track perfectly if you scale in or out a lot, but I don't do that much so I think this'll work out fine.
