Date/Time: Wed, 26 Feb 2025 01:45:55 +0000
Using Sierra Chart through AMP
View Count: 728
[2021-05-06 16:39:05]
User965825 - Posts: 15
I wanted to submit a request at my broker AMP for SC with CQG Data feed. And they told me I have to contact you first.
"if you wish to use sierra with CQG you need to get sierra creds form sierra directly, and also if you do want sierra we would set up on our end with no data from AMP, you would get your data from sierra and pay sierra for the dat not through AMP"
Could you please tell me what I have to do? I just need it for demo (paper) trading. I donĀ“t need a live account. Is it possible to make demo trades with SC and your own data feed?
Regards
[2021-05-06 18:01:45]
John - SC Support - Posts: 38172
You seem to already be setup with the software, as you have an account and a Package selected. If you do not have the Sierra Chart software yet, then you can download it from this link:
Software Download: Software Download
Since you are looking to just use the system for demo/paper trading, then we recommend using the Delayed Exchange Data Feed, which has delayed streaming data from the CME Group and EUREX. The data is 10-15 minutes delayed, depending on symbol, but in all aspects acts the same as live data and includes the Market Depth. There is no additional cost for this data. Refer to the following:
Sierra Chart comes with a built-in Simulation mode that can be used for your demo purposes. But, there is an enhanced Simulated Futures Trading Service that we offer that gives several advantages, including server side orders and account balance. This can also be used with the delayed data. Refer to the following:
