Date/Time: Wed, 26 Feb 2025 01:46:05 +0000
In the cards?
View Count: 503
[2021-05-06 15:45:42]
User940772 - Posts: 76
I’m not sure if this falls within the scope of the questions you take or not but was wondering if there is anything in the cards as it pertains to Iceberg/Stop run detection. It seems like there is a lot of work being done in this area and the one thing that I have learned of Sierra the past three years using your software (trading for 30) is that whatever “they” do, you can do better. Ergo I figured I’d check with you before making a big investment in another program. Either way I am keeping Sierra … to good to let go. ;-)
[2021-05-06 15:54:53]
John - SC Support - Posts: 38172
Nothing specifically with regards to Icebergs is being worked on at this time.
[2021-05-06 16:19:32]
Thanks John
