Date/Time: Wed, 23 Sep 2026 11:23:34 +0000
DOM Link upgrade request
View Count: 883
| [2021-05-05 17:27:49] |
| User98657 - Posts: 420 |
I think it would be a good enhancement if we could lock the vertical DOM pricing to an adjacent chart. We can link Chart vertical scales, but not to the DOM (from what I can see)
| [2021-05-05 18:43:00] |
| John - SC Support - Posts: 47980 |
We are not sure exactly what you are asking for that is not already handled by the Vertical Scales linking. The reason the Trading DOM and a Chart do not move perfectly in sync when they are linked is because the Trading DOM uses a "Constant Range" scale type and can not use Automatic, as there are not bars associated with it. If you change the Chart vertical scale to be Constant Range as well, then it will move in sync with the Trading DOM. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-05-05 19:15:02] |
John, From what I can see, the Trading DOM does not have the ability to link. If I'm mistaken, and the ability to link the Trading DOM is available please let me know. It would be available for Chart with a Chart DOM, but I don't see the ability to link a Trading DOM. |
| [2021-05-05 20:00:54] |
On the Trading DOM select Chart >> Chart Settings >> Advanced Settings 2 and set the link information there, just like on a chart. Just keep in mind that if you close the Trading DOM and open a new one, it is now a new Trading DOM, so the link information will not stay. You would need to save the Trading DOM with the Chartbook and not close it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
