Date/Time: Tue, 25 Feb 2025 23:19:06 +0000
Volume Profile Study drawn onto chart - cannot change ticks per bar setting
View Count: 510
[2021-05-05 16:30:22] |
User71961 - Posts: 144 |
I am drawing a volume profile study onto a chart of 10yr treasury futures (ZN) and this VolumeProfile Settings --> Ticks per volume bar --> [ ] field seems only able to accept numbers by increments of 5....can this be changed to 1 or 2? I would like to be able to see a more granular profile chart...but not able with this setting locked |
[2021-05-05 18:16:24] |
John - SC Support - Posts: 38172 |
When that happens, it implies that you have set the Chart >> Chart Settings >> Volume at Price Multiplier is set to 5. Refer to the following: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) And to the following: Volume By Price Study: Ticks Per Volume Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
