Date/Time: Sun, 22 Dec 2024 19:41:50 +0000
[User Discussion] - Chart histogram of Market Depth
View Count: 2212
[2014-03-11 00:02:04] |
Profile Trader - Posts: 176 |
Is there a way to paint a histogram of the values presently in the depth of market(quantities at each bid and ask level). This would be of interest if someone was doing spoofing.
[2014-03-11 01:10:23] |
Have a look at the Bid & Ask Depth Bars study.
[2014-03-11 01:28:56] |
As I understand the Bid & Ask Depth Bars Study it adds them all together. I was looking for something more like this.
Depth Histogram.jpg / V - Attached On 2014-03-11 01:28:40 UTC - Size: 102.24 KB - 792 views |
[2014-03-13 03:17:27] |
For those also looking for this SC does offer it. If you go into chart settings and Advanced Settings Tab 2 and click on DOM Graph. Thanks Doug |
[2014-03-13 03:43:17] |
Your request was not obvious from your image. It is blurry and has three different arrows on it.
[2014-03-13 03:48:48] |
The coloring of this appears to decrease from red to white on the bid side and from green to white on the offer side. Is this a removable feature for coloring the scheme? I was not able to find any adjustment in the graphics settings with regards to this only color and weight of line. Thanks, Doug |
[2014-03-13 03:51:40] |
The gradient coloring is not changeable but you can change the two primary colors used in the DOM graph through Global Settings >> Graphics Settings.
[2015-05-28 04:00:35] |
Acro - Posts: 441 |
The gradient coloring (ie white for furthest away) is really hard to see on lighter colored backgrounds. Is there any chance you can give us the option to choose between white and black ? Thanks |
