Date/Time: Wed, 26 Feb 2025 01:28:27 +0000
activity log commissions are wrong
View Count: 659
[2021-05-05 15:13:54] |
User61576 - Posts: 445 |
pls check the attached screenshot the minis micro commissions is set for X and as you can see I entered and exited on the same price and showing me the commissions of the global symbol (which is for minis) pls advice thanks |
Private File |
[2021-05-05 15:26:57] |
John - SC Support - Posts: 38172 |
The Global Round Turn Commission takes precedence. Therefore, if you want different commissions, you would need to enter them for all the symbols individually and then remove the Global Round Turn Commission value.
[2021-05-05 16:13:48] |
do i need to restart for it to affect?
[2021-05-05 17:46:49] |
You should not have to. Is it not working as you expect?
[2021-05-05 18:01:51] |
still no change
[2021-05-05 18:44:40] |
Enable Global Round Turn Commissions and enter a value of 0 in the field instead of 4.2 (i.e. remove the value in that field). Then disable the Global Round Turn Commissions. Select OK to close the window. Let us know if that resolves it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-05 18:44:51
[2021-05-05 19:13:45] |
done and still same problem
[2021-05-05 19:56:42] |
Ok, on the Trade Activity Log try turning off the Commission, select Apply, then turn on the Commission and select Apply again. Let us know what happens. Actually, just selecting the Apply button should update it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-05 19:59:07
