Date/Time: Mon, 05 Oct 2026 22:52:41 +0000
AMP Futures / Rithmic / SC order routing service
View Count: 2647
| [2021-05-03 19:40:40] |
| Laurent Donstetter - Posts: 6 |
Hi, I have a live account at AMP Futures with Rithmic data feed. Can I use SC order routing to have charts and trading activated in SC via this account ? If the above doesn't work, which setup can I use to trade Future contracts both with SC and Bookmap, with full market-depth ? Is the only solution to have two accounts with two different data feeds ? Thank you. Best Regards. Laurent. |
| [2021-05-03 20:56:48] |
| John - SC Support - Posts: 48114 |
Really, the only way to do what you want is to have 2 data feeds. You would use the Denali Exchange Data Feed for your Sierra Chart, and you would use the Rithmic data feed for BookMap. Note that the Sierra Chart Order Routing is not available with AMP, and we do not give any technical support for the existing Rithmic connectivity to Sierra Chart. You will need the files specified in this post to use Rithmic with Sierra Chart: Rithmic Bridge Files Also refer to the information for the Denali Exchange Data Feed here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-05-05 14:16:26] |
Thank you for your message. I don't understand though if I can use Rithmic with Sierra Chart. I have a Rithmic login and I also have the files in the Rim folder, how do I use it with Sierra Chart, ? |
| [2021-05-05 14:46:19] |
Go to File >> Data/Trade Service Settings and select Rithmic Trading in the Current Selected Service field. Select the A next to that field to accept it and then you will see additional fields become available under it. Fill those in as necessary.
| [2021-05-05 15:01:35] |
Sorry but it doesn't work. I am using the same login and password that connect me fine in Rithmic Trader. Current Selected Service : Rithmic Trading Server : Rithmic 0S - US Username : same as in Rithmic Trader Password : same as in Rithmic Trader |
| [2021-05-05 15:07:37] |
Sorry I meant Rihmic 01 - US for the server. I have checked the credentials multiple times Rithmic Trading | Bridge process is running. | 2021-05-05 17:05:47.980 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54104 | 2021-05-05 17:05:47.980 DTC Client socket (3) | Creating socket. | 2021-05-05 17:05:47.980 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-05-05 17:05:47.980 DTC Client socket (3) | Connecting to IP: 127.0.0.1. | 2021-05-05 17:05:47.980 Rithmic Trading | Network connection to server complete. | 2021-05-05 17:05:47.981 Rithmic Trading | Starting socket receive thread. | 2021-05-05 17:05:47.981 Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-05-05 17:05:47.981 Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-05-05 17:05:47.982 Rithmic Trading | Sending logon request message. | 2021-05-05 17:05:47.982 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-05-05 17:05:47.984 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-05-05 17:05:47.985 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2021-05-05 17:05:47.985 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2021-05-05 17:05:48.742 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2021-05-05 17:05:49.145 Rithmic Trading | Received logon response. | 2021-05-05 17:05:49.154 Rithmic Trading | Server Name: DTC Bridge. | 2021-05-05 17:05:49.154 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-05-05 17:05:49.154 Rithmic Trading | Logon error received from server | 2021-05-05 17:05:49.154 |
| [2021-05-05 15:12:50] |
The only thing we can tell you is to check the log referenced here: Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log
Otherwise, you are into the realm of where we do not give technical support for Rithmic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
