Date/Time: Wed, 26 Feb 2025 00:33:54 +0000
Issue with Feed not flowing
View Count: 493
[2021-05-03 19:36:14]
JJBB9393 - Posts: 4
I have an issue with Data not flowing. It may have been due to insufficient funds in my Sierra Account, but I have added funds and renewed it today so we should be all square. What do I need to do have the data start flowing again?
I have a CQG feed with AMP and called them to see if there were any issues and the CQG setup is working on their side.
Thanks. Joel
[2021-05-03 20:41:49]
John - SC Support - Posts: 38172
First, you need to change your Service Package to Package 11. You can do this at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#AvailableServices
Then you need to activate the specific exchange(s) for which you want the real-time data. You can do this at the following link:
After that, you should be all set.
[2021-05-03 20:58:40]
JJBB9393 - Posts: 4
So, I am using AMP and using their CQG feed so I am not using Denali. I spoke to AMP Future, and this is no longer supported. Do I need to enable the Denali feed? I will do as you ask, but want to make sure I am creating the data feed correctly.
[2021-05-03 21:21:21]
We see that you have the Denali Exchange Data Feed all setup now. Everything looks good. Let us know if you are not getting the data.
[2021-05-03 22:35:08]
JJBB9393 - Posts: 4
I am receiving data. Thank you...
