Date/Time: Tue, 25 Feb 2025 23:05:34 +0000
como conectar el broker amp futures con sierra chart
View Count: 683
[2021-05-03 17:35:16] |
Usuario859426 - Posts: 1 |
hola, quiero saber si es posible conectar el broker amp futures con sierra chart, en caso de que si sea posible quiero saber como es el procedimiento, gracias
[2021-05-03 19:11:24] |
John - SC Support - Posts: 38172 |
From Google Translate: Hello, I want to know if it is possible to connect the broker amp futures with sierra chart, in case if possible I want to know how the procedure is, thanks
Yes, you can connect Sierra Chart with AMP. When you are setting up your AMP account, let them know that you will be using Sierra Chart and they will set your account to use CQG for order routing. They will then send you a Username and Password for CQG. Once you have these, then follow these instructions to connect your Sierra Chart to CQG: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
