Date/Time: Fri, 07 Feb 2025 15:02:14 +0000
Highlight number bar when close is above POC
View Count: 506
[2021-05-03 16:20:14] |
User600819 - Posts: 43 |
Is it possible to highlight a number bar when the close is above point of control?
[2021-05-03 16:44:18] |
John - SC Support - Posts: 37808 |
There is no way to highlight a Number Bar itself, and the option you are asking for does not exist within the Numbers Bars study. What we would recommend would be to use the Color Bar Based on Alert Condition and use the Point on High subgraph to put a dot above the bar when the condition is met. Refer to the following: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
