Date/Time: Wed, 26 Feb 2025 00:07:47 +0000
Number bars show no bid/ask data
View Count: 825
[2021-05-03 14:34:34] |
User872151 - Posts: 19 |
Hi dear Sierra Chart team, never experienced a problem like this, my charts displaying stocks are not updating. My SPY chart has real-time data and shows the bid/ask sizes but all other stocks dont have real-time data (chart only updates after disconnecting and re-connecting the data feed) and dont show bid/ask data, even after disconnecting. Problem can be seen here: http://prntscr.com/12feu5y Thanks in advance for any help provided! |
[2021-05-03 16:15:52] |
John - SC Support - Posts: 38172 |
Set the stock charts to NOT be continuous futures chart. Refer to the following: Continuous Futures Contract Charts: None Let us know if you continue to have issues after you do the above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-03 16:54:50] |
Changed the setting but problem still persists. Did one change on the weekend which must be the reason for my problem. For most stocks I put in a custom value in: (Symbol Settings > Tick Size), so that when I load the charts, the tick size adapts to the ticker. On the stocks where I didnt put in a custom tick size the charts load the way they should. But if I undo the changes nothing happens. |
[2021-05-03 18:12:28] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-03 18:25:42] |
Ok - here we go. Ticker is AAPL. Message Log: Software version: 2225 64-bit | 2021-05-03 14:22:01.281 Primary Thread ID: 18012 | 2021-05-03 14:22:01.281 Usage end date: 2021-05-19 | 2021-05-03 14:22:01.281 Enabled for: Advanced Features 2. | 2021-05-03 14:22:01.281 Enabled for: Sierra Chart Historical Data Service. | 2021-05-03 14:22:01.281 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-05-03 14:22:01.281 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-05-03 14:22:01.281 Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX) | 2021-05-03 14:22:01.281 Enabled for exchange: Euronext Equities Delayed | 2021-05-03 14:22:01.281 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-05-03 14:22:01.281 Current selected Data/Trading service: SC Data - All Services | 2021-05-03 14:22:01.281 Custom symbol settings values: enabled | 2021-05-03 14:22:01.281 Chart Update Interval: 500 | 2021-05-03 14:22:01.281 Intraday Data Storage Time Unit: 0 | 2021-05-03 14:22:01.281 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-05-03 14:22:01.281 2021-05-03 18:22:01 Local computer time in UTC | 2021-05-03 14:22:01.281 2021-05-03 14:22:01 Local computer time in SC Time Zone | 2021-05-03 14:22:01.281 2021-05-03 17:31:56 Server time in UTC | 2021-05-03 14:22:01.281 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-05-03 14:22:01.281 Program path: C:\SierraChart\ | 2021-05-03 14:22:01.281 Data Files path: C:\SierraChart\Data\ | 2021-05-03 14:22:01.281 OS Version Number: 10.0 | 2021-05-03 14:22:01.282 Locale Setting: C | 2021-05-03 14:22:01.282 DLLs: UserContributedStudies_64.dll | 2021-05-03 14:22:01.282 Allowed protected custom studies: | 2021-05-03 14:22:01.282 File >> Disconnect selected. | 2021-05-03 14:22:18.508 SC Data - All Services | Waiting for socket receive thread to end | 2021-05-03 14:22:18.516 DTC Client socket (1) | CloseSocket call. | 2021-05-03 14:22:18.516 DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-03 14:22:18.517 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-05-03 14:22:18.517 SC Data - All Services | Disconnected from the server. | 2021-05-03 14:22:18.517 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2021-05-03 14:22:18.517 DTC Client socket (4) | CloseSocket call. | 2021-05-03 14:22:18.517 DTC Client socket (4) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-03 14:22:18.517 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-05-03 14:22:18.518 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-05-03 14:22:18.518 SC Data - All Services | Disconnected. | 2021-05-03 14:22:18.518 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-03 14:22:20.879 DTC Client socket (2) | Closed. | 2021-05-03 14:22:20.879 DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-03 14:22:20.879 DTC Client socket (3) | Closed. | 2021-05-03 14:22:20.879 SC Data - All Services | Connected to server complete. | 2021-05-03 14:22:27.721 Triggering next historical data download in queue. | 2021-05-03 14:22:27.723 Triggering next historical data download in queue. | 2021-05-03 14:22:27.723 Triggering next historical data download in queue. | 2021-05-03 14:22:27.723 Triggering next historical data download in queue. | 2021-05-03 14:22:27.723 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-05-03 14:22:27.723 Mapping SPY to SPY. Service code: equities.us | 2021-05-03 14:22:27.724 SC Data - All Services | Starting real-time market data updates for: SPY (SPY). ID: 1 Service code: equities.us | 2021-05-03 14:22:27.724 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-05-03 14:22:27.724 SC Data - All Services | Requesting security definition data for: SPY (SPY). ID: 1 | 2021-05-03 14:22:27.724 Added historical Intraday data request for SPY to the queue. | 2021-05-03 14:22:27.724 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2021-05-03 14:22:27.724 AAPL 5 Min #6 | Started historical data download for additional symbol SPY. Download ID: 161 | 2021-05-03 14:22:27.724 DTC Client socket (22) | Creating socket. | 2021-05-03 14:22:27.724 DTC Client socket (22) | New receive buffer size: 5242880 | 2021-05-03 14:22:27.725 DTC Client socket (22) | Connecting to IP: 8.18.161.135. | 2021-05-03 14:22:27.725 No download requests in the queue to start downloads for. | 2021-05-03 14:22:27.726 Delaying start of download for SPY | 2021-05-03 14:22:27.726 No download requests in the queue to start downloads for. | 2021-05-03 14:22:27.726 No download requests in the queue to start downloads for. | 2021-05-03 14:22:27.726 SC Data - All Services | Network connection to server complete. | 2021-05-03 14:22:27.943 SC Data - All Services | Starting socket receive thread. | 2021-05-03 14:22:27.943 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-05-03 14:22:27.943 SC Data - All Services | Starting real-time market data updates for: AAPL. ID: 2 | 2021-05-03 14:22:28.144 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: AAPL | 2021-05-03 14:22:28.144 SC Data - All Services | Requesting security definition data for: AAPL. ID: 2 | 2021-05-03 14:22:28.144 Added historical Intraday data request for AAPL to the queue. | 2021-05-03 14:22:28.144 Intraday data recording state for symbol AAPL is set to download 'Pending'. | 2021-05-03 14:22:28.144 Triggering next historical data download in queue. | 2021-05-03 14:22:28.144 Delaying start of download for AAPL | 2021-05-03 14:22:28.161 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-05-03 14:22:28.191 SC Data - All Services | Sending logon request message. | 2021-05-03 14:22:28.191 SC Data - All Services | Received logon response. | 2021-05-03 14:22:29.067 SC Data - All Services | Server Name: SC Realtime Server. | 2021-05-03 14:22:29.067 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-05-03 14:22:29.067 SC Data - All Services | Successfully connected. | 2021-05-03 14:22:29.067 SC Data - All Services | Trading is not supported. | 2021-05-03 14:22:29.067 SC Data - All Services | Restarting real-time data updates for symbol: SPY -> SPY | 2021-05-03 14:22:29.067 SC Data - All Services | Received security definition for symbol SPY | 2021-05-03 14:22:29.382 HD Request # 50 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: scdataallservices | 2021-05-03 14:22:33.048 HD Request # 50 | Download start date-time: 2021-05-03 14:05:00.000000. File last date-time: 2021-05-03 14:05:00.000000 | 2021-05-03 14:22:33.049 HD Request # 50 | Requesting historical Intraday Minute data for AAPL starting at 2021-05-03 14:05:00 (Exchange time). | 2021-05-03 14:22:33.049 HD Request # 51 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: equities.us | 2021-05-03 14:22:34.054 HD Request # 51 | Download start date-time: 2021-05-03 14:22:19.000000. File last date-time: 2021-05-03 14:22:19.323000 | 2021-05-03 14:22:34.055 HD Request # 51 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2021-05-03 14:22:34.055 Socket (24) | Creating socket. | 2021-05-03 14:22:34.062 Socket (24) | New receive buffer size: 5242880 | 2021-05-03 14:22:34.062 Socket (24) | Connecting to IP: 8.18.161.133. | 2021-05-03 14:22:34.062 HD Request # 51 | Setting DTC encoding to Binary VLS | 2021-05-03 14:22:34.544 HD Request # 51 | Sending historical data logon request message. | 2021-05-03 14:22:34.544 HD Request # 50 | Receiving Intraday data for AAPL starting at 2021-05-03 14:05:00.000000 | 2021-05-03 14:22:34.760 HD Request # 50 | Bytes received: 165 | 2021-05-03 14:22:34.760 HD Request # 50 | Timestamp of first Intraday data file record written: 2021-05-03 14:06:00.000000 | 2021-05-03 14:22:34.761 HD Request # 50 | Received 3 records from 2021-05-03 14:05:00.000000 to 2021-05-03 14:07:00.000000 (2.0 minutes) and wrote 2 records for AAPL | 2021-05-03 14:22:34.761 HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2021-05-03 18:07:00.000000 | 2021-05-03 14:22:34.762 HD Request # 50 | Completion time: 1s | 2021-05-03 14:22:34.762 HD Request # 50 | Intraday data download complete for AAPL. Unique request ID: 162 | 2021-05-03 14:22:34.762 Removing historical data download ID 162. | 2021-05-03 14:22:34.762 Real-time Intraday chart data file updates started for AAPL | 2021-05-03 14:22:34.762 Intraday chart data file opened for AAPL | 2021-05-03 14:22:34.762 HD Request # 50 | Enabling Intraday chart updating for symbol. | 2021-05-03 14:22:34.762 Triggering next historical data download in queue. | 2021-05-03 14:22:34.762 No download requests in the queue to start downloads for. | 2021-05-03 14:22:34.762 HD Request # 51 | Requesting Intraday data. Start date-time: 2021-05-03 14:22:19. Record interval: 0. Symbol: SPY | 2021-05-03 14:22:35.200 HD Request # 51 | Decompressing data. | 2021-05-03 14:22:35.453 HD Request # 51 | Receiving Intraday data for SPY starting at 2021-05-03 14:22:19.323000 | 2021-05-03 14:22:35.454 Socket (24) | CloseSocket call. | 2021-05-03 14:22:35.454 Socket (24) | 0 bytes remaining in receive buffer when socket closed. | 2021-05-03 14:22:35.454 Socket (24) | Shutdown started. Waiting for graceful close. | 2021-05-03 14:22:35.454 Historical data download thread signaled to stop. | 2021-05-03 14:22:35.454 HD Request # 51 | Timestamp of first Intraday data file record written: 2021-05-03 14:22:19.817000 | 2021-05-03 14:22:35.456 HD Request # 51 | Received 54 records from 2021-05-03 14:22:19.323000 to 2021-05-03 14:22:33.335003 (14.0 seconds) and wrote 53 records for SPY | 2021-05-03 14:22:35.456 HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2021-05-03 18:22:33.335003 | 2021-05-03 14:22:35.457 Added 2 Time and Sales records to Intraday data file for SPY after download. | 2021-05-03 14:22:35.457 HD Request # 51 | Completion time: 1s | 2021-05-03 14:22:35.458 HD Request # 51 | Intraday data download complete for SPY. Unique request ID: 161 | 2021-05-03 14:22:35.458 Removing historical data download ID 161. | 2021-05-03 14:22:35.458 Real-time Intraday chart data file updates started for SPY | 2021-05-03 14:22:35.458 Intraday chart data file opened for SPY | 2021-05-03 14:22:35.458 HD Request # 51 | Enabling Intraday chart updating for symbol. | 2021-05-03 14:22:35.458 AAPL 5 Min #6 | Historical data download for additional symbol SPY with ID 161 has completed. | 2021-05-03 14:22:35.458 Triggering next historical data download in queue. | 2021-05-03 14:22:35.458 No download requests in the queue to start downloads for. | 2021-05-03 14:22:35.458 Socket (24) | Socket gracefully closed by remote side. | 2021-05-03 14:22:35.685 Socket (24) | Closed. | 2021-05-03 14:22:35.685 Opened cached Intraday file: C:\SierraChart\Data\SPY.scid. Thread ID: 11076 | 2021-05-03 14:22:39.318 DTC Client socket (2) | Deleting network socket now after delay. | 2021-05-03 14:22:50.887 DTC Client socket (3) | Deleting network socket now after delay. | 2021-05-03 14:22:50.887 |
[2021-05-03 20:32:33] |
We do not see any issues in the log. Can you get us the AAPL Numbers Bars chart that is showing the issue by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-04 02:40:36] |
Sure, have attached the chart below
![]() Attachment Deleted. |
[2021-05-04 04:47:04] |
Sierra_Chart Engineering - Posts: 18565 |
The Message Log clearly does indicate a problem with Symbol Settings.: SC Data - All Services | Starting real-time market data updates for: AAPL. ID: 2 | 2021-05-03 14:22:28.144
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: AAPL | 2021-05-03 14:22:28.144 HD Request # 50 | Requesting historical Intraday Minute data for AAPL starting at 2021-05-03 14:05:00 (Exchange time). | 2021-05-03 14:22:33.049 You must have changed critical settings or for some reason they are missing. First thing we want you to do is exit from Sierra Chart and then delete all the files in this folder: C:\SierraChart\SymbolSettings And then run Sierra Chart again. You will lose the custom settings but there is some problem those are apparently causing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-04 04:47:58
[2021-05-04 05:47:19] |
Thanks so much for your help with this issue. Followed your instructions, now the last bar displayed on the chart shows again data as usual (http://prntscr.com/12gjdxk). Unfortunately if I want to go back in time there is no data, but thats ok. Chart should update with the new trading data as before.
[2021-05-04 14:00:11] |
To get the previous data follow these instructions to delete and redownload: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
