Date/Time: Mon, 25 Nov 2024 22:46:48 +0000
OEC still disconnected multiple times during the day
View Count: 1655
[2014-03-10 14:55:35] |
doctor.scalp - Posts: 18 |
Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 14:53:03 OEC FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2014-03-10 14:53:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-10 14:53:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-10 14:53:03 Disconnected from Open E Cry. | 2014-03-10 14:53:03 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 14:53:03 OEC FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2014-03-10 14:53:03 The SSL socket was shut down successfully. | 2014-03-10 14:53:03 OEC FIX Trading: Socket closed without completing the logout sequence. | 2014-03-10 14:53:03 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 14:53:05 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 14:53:05 The network socket is connected. | 2014-03-10 14:53:05 Starting SSL connection on the socket. | 2014-03-10 14:53:05 SSL socket is now connected. | 2014-03-10 14:53:06 OEC FIX Trading: Sending the Logon message. | 2014-03-10 14:53:06 Connection timed out. Will disconnect and retry. | 2014-03-10 14:54:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-10 14:54:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-10 14:54:05 OEC FIX Trading: Sending a Logout message. | 2014-03-10 14:54:05 Disconnected from Open E Cry. | 2014-03-10 14:54:05 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 14:54:05 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 14:54:07 OEC FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2014-03-10 14:54:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-10 14:54:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-10 14:54:07 Disconnected from Open E Cry. | 2014-03-10 14:54:07 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 14:54:07 OEC FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2014-03-10 14:54:09 The SSL socket was shut down successfully. | 2014-03-10 14:54:09 OEC FIX Trading: Socket closed without completing the logout sequence. | 2014-03-10 14:54:09 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 14:54:09 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 14:54:09 The network socket is connected. | 2014-03-10 14:54:09 Starting SSL connection on the socket. | 2014-03-10 14:54:09 SSL socket is now connected. | 2014-03-10 14:54:10 OEC FIX Trading: Sending the Logon message. | 2014-03-10 14:54:10 Open E Cry FIX/FAST: Connected to trading server. | 2014-03-10 14:54:10 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-03-10 14:54:10 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 14:54:10 The network socket is connected. | 2014-03-10 14:54:10 OEC FAST Data: Sending the Hello message. | 2014-03-10 14:54:10 OEC FAST Data: Sending the Logon message. | 2014-03-10 14:54:10 Open E Cry FIX/FAST: Connected to the market data server. | 2014-03-10 14:54:10 Open E Cry FIX/FAST: Connected. | 2014-03-10 14:54:10 Open E Cry FIX/FAST - Starting real-time market data updates for: FESXH4 | 2014-03-10 14:54:10 HD Request # 7 - Downloading Intraday chart data for FESXH4 to the file FESXH4.scid. Service: oec | 2014-03-10 14:54:10 HD Request # 7 - Download start Date-Time: 2014-03-10 14:48:38.0 | 2014-03-10 14:54:10 HD Request # 7 - Using server: ds4.sierracharts.com port 10149 | 2014-03-10 14:54:10 Open E Cry FIX/FAST - Starting real-time market data updates for: FDAXH4 | 2014-03-10 14:54:10 Open E Cry FIX/FAST - Starting real-time market data updates for: ESH4 | 2014-03-10 14:54:10 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-10 14:54:11 Open E Cry FIX/FAST - Starting real-time market data updates for: YMH4 | 2014-03-10 14:54:11 SC Market Stats - Starting real-time market data updates for: TICK-NYSE | 2014-03-10 14:54:11 SC Market Stats: Connecting to the server ds3.sierracharts.com. Port 443 | 2014-03-10 14:54:11 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-10 14:54:11 The network socket is connected. | 2014-03-10 14:54:11 HD Request # 7 - Sending historical data logon request message. | 2014-03-10 14:54:11 HD Request # 7 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 13:48:38. Record interval: 0 | 2014-03-10 14:54:11 HD Request # 7 - Decompressing data. | 2014-03-10 14:54:11 HD Request # 7 - Receiving Intraday data for FESXH4 starting at 2014-03-10 14:48:38 | 2014-03-10 14:54:11 HD Request # 7 - Timestamp of first Intraday data file record written: 2014-03-10 14:48:38 | 2014-03-10 14:54:11 The network socket for historical data has been closed. | 2014-03-10 14:54:11 HD Request # 7 - Received 340 records from 2014-03-10 14:48:38 to 2014-03-10 14:54:14 (5.6 minutes) and wrote 338 records for FESXH4 | 2014-03-10 14:54:11 HD Request # 7 - Intraday download COMPLETE for FESXH4 | 2014-03-10 14:54:11 Real-time Intraday chart data file updates started for FESXH4 | 2014-03-10 14:54:11 HD Request # 8 - Downloading Intraday chart data for FDAXH4 to the file FDAXH4.scid. Service: oec | 2014-03-10 14:54:11 HD Request # 8 - Download start Date-Time: 2014-03-10 14:48:44.0 | 2014-03-10 14:54:11 HD Request # 8 - Using server: ds5.sierracharts.com port 10149 | 2014-03-10 14:54:11 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-10 14:54:11 The network socket is connected. | 2014-03-10 14:54:11 HD Request # 8 - Sending historical data logon request message. | 2014-03-10 14:54:11 HD Request # 8 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 13:48:44. Record interval: 0 | 2014-03-10 14:54:11 HD Request # 8 - Decompressing data. | 2014-03-10 14:54:12 HD Request # 8 - Receiving Intraday data for FDAXH4 starting at 2014-03-10 14:48:44 | 2014-03-10 14:54:12 HD Request # 8 - Timestamp of first Intraday data file record written: 2014-03-10 14:48:44 | 2014-03-10 14:54:12 The network socket for historical data has been closed. | 2014-03-10 14:54:12 HD Request # 8 - Received 474 records from 2014-03-10 14:48:44 to 2014-03-10 14:54:15 (5.5 minutes) and wrote 473 records for FDAXH4 | 2014-03-10 14:54:12 HD Request # 8 - Intraday download COMPLETE for FDAXH4 | 2014-03-10 14:54:12 Real-time Intraday chart data file updates started for FDAXH4 | 2014-03-10 14:54:12 HD Request # 9 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: oec | 2014-03-10 14:54:12 HD Request # 9 - Download start Date-Time: 2014-03-10 14:48:43.0 | 2014-03-10 14:54:12 HD Request # 9 - Using server: ds4.sierracharts.com port 10149 | 2014-03-10 14:54:12 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-10 14:54:12 The network socket is connected. | 2014-03-10 14:54:12 HD Request # 9 - Sending historical data logon request message. | 2014-03-10 14:54:12 The network socket is connected. | 2014-03-10 14:54:12 SC Market Stats: Connected to server. | 2014-03-10 14:54:12 SC Market Stats: Sending logon request message. | 2014-03-10 14:54:12 HD Request # 9 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 13:48:43. Record interval: 0 | 2014-03-10 14:54:12 HD Request # 9 - Decompressing data. | 2014-03-10 14:54:12 HD Request # 9 - Receiving Intraday data for ESH4 starting at 2014-03-10 14:48:43 | 2014-03-10 14:54:12 HD Request # 9 - Timestamp of first Intraday data file record written: 2014-03-10 14:48:43 | 2014-03-10 14:54:12 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-03-10 14:54:12 SC Market Stats - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-10 14:54:12 SC Market Stats - Successfully connected. | 2014-03-10 14:54:12 SC Market Stats - Restarting real-time data updates for symbol: TICK-NYSE | 2014-03-10 14:54:12 The network socket for historical data has been closed. | 2014-03-10 14:54:13 HD Request # 9 - Received 4358 records from 2014-03-10 14:48:43 to 2014-03-10 14:54:14 (5.5 minutes) and wrote 4357 records for ESH4 | 2014-03-10 14:54:13 Added 4 Time and Sales records to Intraday data file for ESH4 after download. | 2014-03-10 14:54:13 HD Request # 9 - Intraday download COMPLETE for ESH4 | 2014-03-10 14:54:13 Real-time Intraday chart data file updates started for ESH4 | 2014-03-10 14:54:13 HD Request # 10 - Downloading Intraday chart data for YMH4 to the file YMH4.scid. Service: oec | 2014-03-10 14:54:13 HD Request # 10 - Download start Date-Time: 2014-03-10 14:48:43.0 | 2014-03-10 14:54:13 HD Request # 10 - Using server: ds3.sierracharts.com port 10149 | 2014-03-10 14:54:13 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-10 14:54:13 The network socket is connected. | 2014-03-10 14:54:13 HD Request # 10 - Sending historical data logon request message. | 2014-03-10 14:54:13 HD Request # 10 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 13:48:43. Record interval: 0 | 2014-03-10 14:54:13 HD Request # 10 - Decompressing data. | 2014-03-10 14:54:13 HD Request # 10 - Receiving Intraday data for YMH4 starting at 2014-03-10 14:48:43 | 2014-03-10 14:54:13 HD Request # 10 - Timestamp of first Intraday data file record written: 2014-03-10 14:48:44 | 2014-03-10 14:54:13 The network socket for historical data has been closed. | 2014-03-10 14:54:13 HD Request # 10 - Received 1024 records from 2014-03-10 14:48:43 to 2014-03-10 14:54:13 (5.5 minutes) and wrote 1023 records for YMH4 | 2014-03-10 14:54:13 HD Request # 10 - Intraday download COMPLETE for YMH4 | 2014-03-10 14:54:13 Real-time Intraday chart data file updates started for YMH4 | 2014-03-10 14:54:13 HD Request # 11 - Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-03-10 14:54:13 HD Request # 11 - Download start Date-Time: 2014-03-10 14:51:28.0 | 2014-03-10 14:54:13 HD Request # 11 - Using server: ds5.sierracharts.com port 10149 | 2014-03-10 14:54:13 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-10 14:54:13 The network socket is connected. | 2014-03-10 14:54:14 HD Request # 11 - Sending historical data logon request message. | 2014-03-10 14:54:14 HD Request # 11 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 13:51:28. Record interval: 0 | 2014-03-10 14:54:14 HD Request # 11 - Decompressing data. | 2014-03-10 14:54:14 HD Request # 11 - Receiving Intraday data for TICK-NYSE starting at 2014-03-10 14:51:28 | 2014-03-10 14:54:14 HD Request # 11 - Timestamp of first Intraday data file record written: 2014-03-10 14:51:29 | 2014-03-10 14:54:14 The network socket for historical data has been closed. | 2014-03-10 14:54:14 HD Request # 11 - Received 170 records from 2014-03-10 14:51:28 to 2014-03-10 14:54:17 (2.8 minutes) and wrote 169 records for TICK-NYSE | 2014-03-10 14:54:14 Added 4 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2014-03-10 14:54:14 HD Request # 11 - Intraday download COMPLETE for TICK-NYSE | 2014-03-10 14:54:14 Real-time Intraday chart data file updates started for TICK-NYSE | 2014-03-10 14:54:14 Requesting market depth updates for: ESH4 if supported. | 2014-03-10 14:54:15 Requesting market depth updates for: FDAXH4 if supported. | 2014-03-10 14:54:15 Requesting market depth updates for: FESXH4 if supported. | 2014-03-10 14:54:15 Requesting market depth updates for: YMH4 if supported. | 2014-03-10 14:54:15 Open E Cry FIX/FAST: Received position acknowledgment message. Request Result: 2. Request Status: 1 | 2014-03-10 14:54:25 Deleted 12 records for [Sim]FESXH4 from Trade Activity Log | 2014-03-10 15:11:46 Deleted 6 records for [Sim]FESXH4 from Trade Activity Log | 2014-03-10 15:12:05 Deleted 6 records for [Sim]FESXH4 from Trade Activity Log | 2014-03-10 15:15:18 Deleted 18 records for [Sim]FESXH4 from Trade Activity Log | 2014-03-10 15:20:11 Socket closed. No error. | 2014-03-10 15:29:23 The SSL socket was shut down successfully. | 2014-03-10 15:29:23 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-10 15:29:23 Connection to the external service has been lost. | 2014-03-10 15:29:23 OEC FAST Data: Sending a Logout message. | 2014-03-10 15:29:23 Disconnected from Open E Cry. | 2014-03-10 15:29:23 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 15:29:23 Socket closed. No error. | 2014-03-10 15:29:23 OEC FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2014-03-10 15:29:23 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 15:29:25 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 15:29:25 The network socket is connected. | 2014-03-10 15:29:25 Starting SSL connection on the socket. | 2014-03-10 15:29:25 SSL socket is now connected. | 2014-03-10 15:29:25 OEC FIX Trading: Sending the Logon message. | 2014-03-10 15:29:25 Open E Cry FIX/FAST: Connected to trading server. | 2014-03-10 15:29:30 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-03-10 15:29:30 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 15:29:30 The network socket is connected. | 2014-03-10 15:29:30 OEC FAST Data: Sending the Hello message. | 2014-03-10 15:29:30 OEC FAST Data: Sending the Logon message. | 2014-03-10 15:29:32 Open E Cry FIX/FAST: Connected to the market data server. | 2014-03-10 15:29:33 Open E Cry FIX/FAST: Connected. | 2014-03-10 15:29:33 SC Market Stats: Disconnected from the server. | 2014-03-10 15:29:33 Open E Cry FIX/FAST - Starting real-time market data updates for: FESXH4 | 2014-03-10 15:29:33 HD Request # 12 - Downloading Intraday chart data for FESXH4 to the file FESXH4.scid. Service: oec | 2014-03-10 15:29:33 HD Request # 12 - Download start Date-Time: 2014-03-10 15:29:24.0 | 2014-03-10 15:29:33 HD Request # 12 - Using server: ds4.sierracharts.com port 10149 | 2014-03-10 15:29:33 Open E Cry FIX/FAST - Starting real-time market data updates for: YMH4 | 2014-03-10 15:29:33 Open E Cry FIX/FAST - Starting real-time market data updates for: ESH4 | 2014-03-10 15:29:33 Open E Cry FIX/FAST - Starting real-time market data updates for: FDAXH4 | 2014-03-10 15:29:33 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-10 15:29:33 SC Market Stats - Starting real-time market data updates for: TICK-NYSE | 2014-03-10 15:29:33 SC Market Stats: Connecting to the server ds3.sierracharts.com. Port 443 | 2014-03-10 15:29:33 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-10 15:29:33 The network socket is connected. | 2014-03-10 15:29:33 HD Request # 12 - Sending historical data logon request message. | 2014-03-10 15:29:33 The network socket is connected. | 2014-03-10 15:29:33 SC Market Stats: Connected to server. | 2014-03-10 15:29:33 SC Market Stats: Sending logon request message. | 2014-03-10 15:29:33 HD Request # 12 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:29:24. Record interval: 0 | 2014-03-10 15:29:34 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-03-10 15:29:34 SC Market Stats - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-10 15:29:34 SC Market Stats - Successfully connected. | 2014-03-10 15:29:34 SC Market Stats - Restarting real-time data updates for symbol: TICK-NYSE | 2014-03-10 15:29:34 HD Request # 12 - Decompressing data. | 2014-03-10 15:29:34 HD Request # 12 - Receiving Intraday data for FESXH4 starting at 2014-03-10 15:29:24 | 2014-03-10 15:29:34 HD Request # 12 - Timestamp of first Intraday data file record written: 2014-03-10 15:29:28 | 2014-03-10 15:29:34 The network socket for historical data has been closed. | 2014-03-10 15:29:34 HD Request # 12 - Received 5 records from 2014-03-10 15:29:24 to 2014-03-10 15:29:36 (12.0 seconds) and wrote 4 records for FESXH4 | 2014-03-10 15:29:34 HD Request # 12 - Intraday download COMPLETE for FESXH4 | 2014-03-10 15:29:34 Real-time Intraday chart data file updates started for FESXH4 | 2014-03-10 15:29:34 HD Request # 13 - Downloading Intraday chart data for YMH4 to the file YMH4.scid. Service: oec | 2014-03-10 15:29:34 HD Request # 13 - Download start Date-Time: 2014-03-10 15:29:26.0 | 2014-03-10 15:29:34 HD Request # 13 - Using server: ds5.sierracharts.com port 10149 | 2014-03-10 15:29:34 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-10 15:29:34 The network socket is connected. | 2014-03-10 15:29:34 HD Request # 13 - Sending historical data logon request message. | 2014-03-10 15:29:34 HD Request # 13 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:29:26. Record interval: 0 | 2014-03-10 15:29:34 HD Request # 13 - Decompressing data. | 2014-03-10 15:29:35 HD Request # 13 - Receiving Intraday data for YMH4 starting at 2014-03-10 15:29:26 | 2014-03-10 15:29:35 HD Request # 13 - Timestamp of first Intraday data file record written: 2014-03-10 15:29:26 | 2014-03-10 15:29:35 The network socket for historical data has been closed. | 2014-03-10 15:29:35 HD Request # 13 - Received 21 records from 2014-03-10 15:29:26 to 2014-03-10 15:29:37 (11.0 seconds) and wrote 20 records for YMH4 | 2014-03-10 15:29:35 HD Request # 13 - Intraday download COMPLETE for YMH4 | 2014-03-10 15:29:35 Real-time Intraday chart data file updates started for YMH4 | 2014-03-10 15:29:35 HD Request # 14 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: oec | 2014-03-10 15:29:35 HD Request # 14 - Download start Date-Time: 2014-03-10 15:29:26.0 | 2014-03-10 15:29:35 HD Request # 14 - Using server: ds4.sierracharts.com port 10149 | 2014-03-10 15:29:35 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-10 15:29:35 The network socket is connected. | 2014-03-10 15:29:35 HD Request # 14 - Sending historical data logon request message. | 2014-03-10 15:29:35 HD Request # 14 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:29:26. Record interval: 0 | 2014-03-10 15:29:35 HD Request # 14 - Decompressing data. | 2014-03-10 15:29:35 HD Request # 14 - Receiving Intraday data for ESH4 starting at 2014-03-10 15:29:26 | 2014-03-10 15:29:35 HD Request # 14 - Timestamp of first Intraday data file record written: 2014-03-10 15:29:28 | 2014-03-10 15:29:35 The network socket for historical data has been closed. | 2014-03-10 15:29:35 HD Request # 14 - Received 170 records from 2014-03-10 15:29:26 to 2014-03-10 15:29:37 (11.0 seconds) and wrote 168 records for ESH4 | 2014-03-10 15:29:35 Added 1 Time and Sales records to Intraday data file for ESH4 after download. | 2014-03-10 15:29:35 HD Request # 14 - Intraday download COMPLETE for ESH4 | 2014-03-10 15:29:35 Real-time Intraday chart data file updates started for ESH4 | 2014-03-10 15:29:35 HD Request # 15 - Downloading Intraday chart data for FDAXH4 to the file FDAXH4.scid. Service: oec | 2014-03-10 15:29:35 HD Request # 15 - Download start Date-Time: 2014-03-10 15:29:26.0 | 2014-03-10 15:29:35 HD Request # 15 - Using server: ds3.sierracharts.com port 10149 | 2014-03-10 15:29:35 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-10 15:29:35 The network socket is connected. | 2014-03-10 15:29:35 HD Request # 15 - Sending historical data logon request message. | 2014-03-10 15:29:35 HD Request # 15 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:29:26. Record interval: 0 | 2014-03-10 15:29:35 HD Request # 15 - Decompressing data. | 2014-03-10 15:29:36 HD Request # 15 - Receiving Intraday data for FDAXH4 starting at 2014-03-10 15:29:26 | 2014-03-10 15:29:36 HD Request # 15 - Timestamp of first Intraday data file record written: 2014-03-10 15:29:26 | 2014-03-10 15:29:36 The network socket for historical data has been closed. | 2014-03-10 15:29:36 HD Request # 15 - Received 30 records from 2014-03-10 15:29:26 to 2014-03-10 15:29:39 (13.0 seconds) and wrote 29 records for FDAXH4 | 2014-03-10 15:29:36 HD Request # 15 - Intraday download COMPLETE for FDAXH4 | 2014-03-10 15:29:36 Real-time Intraday chart data file updates started for FDAXH4 | 2014-03-10 15:29:36 HD Request # 16 - Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-03-10 15:29:36 HD Request # 16 - Download start Date-Time: 2014-03-10 15:29:37.0 | 2014-03-10 15:29:36 HD Request # 16 - Using server: ds5.sierracharts.com port 10149 | 2014-03-10 15:29:36 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-10 15:29:36 The network socket is connected. | 2014-03-10 15:29:36 HD Request # 16 - Sending historical data logon request message. | 2014-03-10 15:29:36 HD Request # 16 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:29:37. Record interval: 0 | 2014-03-10 15:29:36 HD Request # 16 - Decompressing data. | 2014-03-10 15:29:36 HD Request # 16 - Receiving Intraday data for TICK-NYSE starting at 2014-03-10 15:29:37 | 2014-03-10 15:29:36 HD Request # 16 - Timestamp of first Intraday data file record written: 2014-03-10 15:29:38 | 2014-03-10 15:29:36 The network socket for historical data has been closed. | 2014-03-10 15:29:36 HD Request # 16 - Received 3 records from 2014-03-10 15:29:37 to 2014-03-10 15:29:39 (2.0 seconds) and wrote 2 records for TICK-NYSE | 2014-03-10 15:29:36 Added 6 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2014-03-10 15:29:36 HD Request # 16 - Intraday download COMPLETE for TICK-NYSE | 2014-03-10 15:29:36 Real-time Intraday chart data file updates started for TICK-NYSE | 2014-03-10 15:29:36 Requesting market depth updates for: ESH4 if supported. | 2014-03-10 15:29:38 Requesting market depth updates for: FDAXH4 if supported. | 2014-03-10 15:29:38 Requesting market depth updates for: FESXH4 if supported. | 2014-03-10 15:29:38 Requesting market depth updates for: YMH4 if supported. | 2014-03-10 15:29:38 Open E Cry FIX/FAST: Received position acknowledgment message. Request Result: 2. Request Status: 1 | 2014-03-10 15:29:45 Socket closed. Windows error code 10053: Une connexion établie a été abandonnée par un logiciel de votre ordinateur hôte. | 2014-03-10 15:53:21 The SSL socket was shut down successfully. | 2014-03-10 15:53:21 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-10 15:53:21 Connection to the external service has been lost. | 2014-03-10 15:53:21 OEC FAST Data: Sending a Logout message. | 2014-03-10 15:53:21 Disconnected from Open E Cry. | 2014-03-10 15:53:21 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 15:53:21 Socket closed. No error. | 2014-03-10 15:53:21 OEC FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2014-03-10 15:53:21 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 15:53:23 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 15:53:23 The network socket is connected. | 2014-03-10 15:53:23 Starting SSL connection on the socket. | 2014-03-10 15:53:23 SSL socket is now connected. | 2014-03-10 15:53:24 OEC FIX Trading: Sending the Logon message. | 2014-03-10 15:53:24 Connection timed out. Will disconnect and retry. | 2014-03-10 15:54:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-10 15:54:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-10 15:54:23 OEC FIX Trading: Sending a Logout message. | 2014-03-10 15:54:23 Disconnected from Open E Cry. | 2014-03-10 15:54:23 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 15:54:23 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 15:54:25 OEC FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2014-03-10 15:54:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-10 15:54:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-10 15:54:25 Disconnected from Open E Cry. | 2014-03-10 15:54:25 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 15:54:25 OEC FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2014-03-10 15:54:27 The SSL socket was shut down successfully. | 2014-03-10 15:54:27 OEC FIX Trading: Socket closed without completing the logout sequence. | 2014-03-10 15:54:27 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 15:54:27 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 15:54:27 The network socket is connected. | 2014-03-10 15:54:27 Starting SSL connection on the socket. | 2014-03-10 15:54:27 SSL socket is now connected. | 2014-03-10 15:54:28 OEC FIX Trading: Sending the Logon message. | 2014-03-10 15:54:28 |
[2014-03-10 15:31:38] |
And again ... Connection timed out. Will disconnect and retry. | 2014-03-10 15:55:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-10 15:55:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-10 15:55:27 OEC FIX Trading: Sending a Logout message. | 2014-03-10 15:55:27 Disconnected from Open E Cry. | 2014-03-10 15:55:27 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 15:55:27 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 15:55:29 OEC FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2014-03-10 15:55:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-10 15:55:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-10 15:55:29 Disconnected from Open E Cry. | 2014-03-10 15:55:29 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 15:55:29 OEC FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2014-03-10 15:55:31 The SSL socket was shut down successfully. | 2014-03-10 15:55:31 OEC FIX Trading: Socket closed without completing the logout sequence. | 2014-03-10 15:55:31 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 15:55:31 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 15:55:31 The network socket is connected. | 2014-03-10 15:55:31 Starting SSL connection on the socket. | 2014-03-10 15:55:31 SSL socket is now connected. | 2014-03-10 15:55:32 OEC FIX Trading: Sending the Logon message. | 2014-03-10 15:55:32 Open E Cry FIX/FAST: Connected to trading server. | 2014-03-10 15:55:32 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-03-10 15:55:32 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 15:55:32 The network socket is connected. | 2014-03-10 15:55:32 OEC FAST Data: Sending the Hello message. | 2014-03-10 15:55:32 OEC FAST Data: Sending the Logon message. | 2014-03-10 15:55:32 Open E Cry FIX/FAST: Connected to the market data server. | 2014-03-10 15:55:33 Open E Cry FIX/FAST: Connected. | 2014-03-10 15:55:33 SC Market Stats: Disconnected from the server. | 2014-03-10 15:55:33 Open E Cry FIX/FAST - Starting real-time market data updates for: YMH4 | 2014-03-10 15:55:33 HD Request # 17 - Downloading Intraday chart data for YMH4 to the file YMH4.scid. Service: oec | 2014-03-10 15:55:33 HD Request # 17 - Download start Date-Time: 2014-03-10 15:53:25.0 | 2014-03-10 15:55:33 HD Request # 17 - Using server: ds4.sierracharts.com port 10149 | 2014-03-10 15:55:33 Open E Cry FIX/FAST - Starting real-time market data updates for: FDAXH4 | 2014-03-10 15:55:33 Open E Cry FIX/FAST - Starting real-time market data updates for: ESH4 | 2014-03-10 15:55:33 Open E Cry FIX/FAST - Starting real-time market data updates for: FESXH4 | 2014-03-10 15:55:33 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-10 15:55:33 SC Market Stats - Starting real-time market data updates for: TICK-NYSE | 2014-03-10 15:55:33 SC Market Stats: Connecting to the server ds3.sierracharts.com. Port 443 | 2014-03-10 15:55:33 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-10 15:55:33 The network socket is connected. | 2014-03-10 15:55:33 HD Request # 17 - Sending historical data logon request message. | 2014-03-10 15:55:33 The network socket is connected. | 2014-03-10 15:55:33 SC Market Stats: Connected to server. | 2014-03-10 15:55:33 SC Market Stats: Sending logon request message. | 2014-03-10 15:55:33 HD Request # 17 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:53:25. Record interval: 0 | 2014-03-10 15:55:33 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-03-10 15:55:33 SC Market Stats - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-10 15:55:33 SC Market Stats - Successfully connected. | 2014-03-10 15:55:33 SC Market Stats - Restarting real-time data updates for symbol: TICK-NYSE | 2014-03-10 15:55:33 HD Request # 17 - Decompressing data. | 2014-03-10 15:55:33 HD Request # 17 - Receiving Intraday data for YMH4 starting at 2014-03-10 15:53:25 | 2014-03-10 15:55:33 HD Request # 17 - Timestamp of first Intraday data file record written: 2014-03-10 15:53:25 | 2014-03-10 15:55:33 The network socket for historical data has been closed. | 2014-03-10 15:55:33 HD Request # 17 - Received 346 records from 2014-03-10 15:53:25 to 2014-03-10 15:55:36 (2.2 minutes) and wrote 345 records for YMH4 | 2014-03-10 15:55:33 HD Request # 17 - Intraday download COMPLETE for YMH4 | 2014-03-10 15:55:33 Real-time Intraday chart data file updates started for YMH4 | 2014-03-10 15:55:33 HD Request # 18 - Downloading Intraday chart data for FDAXH4 to the file FDAXH4.scid. Service: oec | 2014-03-10 15:55:33 HD Request # 18 - Download start Date-Time: 2014-03-10 15:53:22.0 | 2014-03-10 15:55:33 HD Request # 18 - Using server: ds5.sierracharts.com port 10149 | 2014-03-10 15:55:33 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-10 15:55:33 The network socket is connected. | 2014-03-10 15:55:33 HD Request # 18 - Sending historical data logon request message. | 2014-03-10 15:55:33 HD Request # 18 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:53:22. Record interval: 0 | 2014-03-10 15:55:34 HD Request # 18 - Decompressing data. | 2014-03-10 15:55:34 HD Request # 18 - Receiving Intraday data for FDAXH4 starting at 2014-03-10 15:53:22 | 2014-03-10 15:55:34 HD Request # 18 - Timestamp of first Intraday data file record written: 2014-03-10 15:53:22 | 2014-03-10 15:55:34 The network socket for historical data has been closed. | 2014-03-10 15:55:34 HD Request # 18 - Received 161 records from 2014-03-10 15:53:22 to 2014-03-10 15:55:37 (2.2 minutes) and wrote 159 records for FDAXH4 | 2014-03-10 15:55:34 HD Request # 18 - Intraday download COMPLETE for FDAXH4 | 2014-03-10 15:55:34 Real-time Intraday chart data file updates started for FDAXH4 | 2014-03-10 15:55:34 HD Request # 19 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: oec | 2014-03-10 15:55:34 HD Request # 19 - Download start Date-Time: 2014-03-10 15:53:25.0 | 2014-03-10 15:55:34 HD Request # 19 - Using server: ds4.sierracharts.com port 10149 | 2014-03-10 15:55:34 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-10 15:55:34 The network socket is connected. | 2014-03-10 15:55:34 HD Request # 19 - Sending historical data logon request message. | 2014-03-10 15:55:34 HD Request # 19 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:53:25. Record interval: 0 | 2014-03-10 15:55:34 HD Request # 19 - Decompressing data. | 2014-03-10 15:55:34 HD Request # 19 - Receiving Intraday data for ESH4 starting at 2014-03-10 15:53:25 | 2014-03-10 15:55:34 HD Request # 19 - Timestamp of first Intraday data file record written: 2014-03-10 15:53:25 | 2014-03-10 15:55:34 The network socket for historical data has been closed. | 2014-03-10 15:55:34 HD Request # 19 - Received 1468 records from 2014-03-10 15:53:25 to 2014-03-10 15:55:33 (2.1 minutes) and wrote 1467 records for ESH4 | 2014-03-10 15:55:34 Added 1 Time and Sales records to Intraday data file for ESH4 after download. | 2014-03-10 15:55:34 HD Request # 19 - Intraday download COMPLETE for ESH4 | 2014-03-10 15:55:34 Real-time Intraday chart data file updates started for ESH4 | 2014-03-10 15:55:34 HD Request # 20 - Downloading Intraday chart data for FESXH4 to the file FESXH4.scid. Service: oec | 2014-03-10 15:55:34 HD Request # 20 - Download start Date-Time: 2014-03-10 15:53:21.0 | 2014-03-10 15:55:34 HD Request # 20 - Using server: ds3.sierracharts.com port 10149 | 2014-03-10 15:55:34 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-10 15:55:34 The network socket is connected. | 2014-03-10 15:55:34 HD Request # 20 - Sending historical data logon request message. | 2014-03-10 15:55:34 HD Request # 20 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:53:21. Record interval: 0 | 2014-03-10 15:55:34 HD Request # 20 - Decompressing data. | 2014-03-10 15:55:35 HD Request # 20 - Receiving Intraday data for FESXH4 starting at 2014-03-10 15:53:21 | 2014-03-10 15:55:35 HD Request # 20 - Timestamp of first Intraday data file record written: 2014-03-10 15:53:21 | 2014-03-10 15:55:35 The network socket for historical data has been closed. | 2014-03-10 15:55:35 HD Request # 20 - Received 103 records from 2014-03-10 15:53:21 to 2014-03-10 15:55:38 (2.3 minutes) and wrote 102 records for FESXH4 | 2014-03-10 15:55:35 HD Request # 20 - Intraday download COMPLETE for FESXH4 | 2014-03-10 15:55:35 Real-time Intraday chart data file updates started for FESXH4 | 2014-03-10 15:55:35 HD Request # 21 - Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-03-10 15:55:35 HD Request # 21 - Download start Date-Time: 2014-03-10 15:55:36.0 | 2014-03-10 15:55:35 HD Request # 21 - Using server: ds5.sierracharts.com port 10149 | 2014-03-10 15:55:35 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-10 15:55:35 The network socket is connected. | 2014-03-10 15:55:35 HD Request # 21 - Sending historical data logon request message. | 2014-03-10 15:55:35 HD Request # 21 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 14:55:36. Record interval: 0 | 2014-03-10 15:55:35 HD Request # 21 - Decompressing data. | 2014-03-10 15:55:35 HD Request # 21 - Receiving Intraday data for TICK-NYSE starting at 2014-03-10 15:55:36 | 2014-03-10 15:55:35 HD Request # 21 - Timestamp of first Intraday data file record written: 2014-03-10 15:55:37 | 2014-03-10 15:55:35 The network socket for historical data has been closed. | 2014-03-10 15:55:35 HD Request # 21 - Received 4 records from 2014-03-10 15:55:36 to 2014-03-10 15:55:39 (3.0 seconds) and wrote 3 records for TICK-NYSE | 2014-03-10 15:55:35 HD Request # 21 - Intraday download COMPLETE for TICK-NYSE | 2014-03-10 15:55:35 Real-time Intraday chart data file updates started for TICK-NYSE | 2014-03-10 15:55:35 Requesting market depth updates for: ESH4 if supported. | 2014-03-10 15:55:38 Requesting market depth updates for: FDAXH4 if supported. | 2014-03-10 15:55:38 Requesting market depth updates for: FESXH4 if supported. | 2014-03-10 15:55:38 Requesting market depth updates for: YMH4 if supported. | 2014-03-10 15:55:38 Open E Cry FIX/FAST: Received position acknowledgment message. Request Result: 2. Request Status: 1 | 2014-03-10 15:55:47 Deleted 16 records for [Sim]FESXH4 from Trade Activity Log | 2014-03-10 16:00:37 Socket closed. No error. | 2014-03-10 16:29:45 The SSL socket was shut down successfully. | 2014-03-10 16:29:45 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-03-10 16:29:45 Connection to the external service has been lost. | 2014-03-10 16:29:45 OEC FAST Data: Sending a Logout message. | 2014-03-10 16:29:45 Disconnected from Open E Cry. | 2014-03-10 16:29:45 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-10 16:29:45 Socket closed. No error. | 2014-03-10 16:29:45 OEC FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2014-03-10 16:29:45 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-03-10 16:29:47 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 16:29:47 The network socket is connected. | 2014-03-10 16:29:47 Starting SSL connection on the socket. | 2014-03-10 16:29:47 SSL socket is now connected. | 2014-03-10 16:29:47 OEC FIX Trading: Sending the Logon message. | 2014-03-10 16:29:48 Open E Cry FIX/FAST: Connected to trading server. | 2014-03-10 16:29:53 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-03-10 16:29:53 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-03-10 16:29:53 The network socket is connected. | 2014-03-10 16:29:53 OEC FAST Data: Sending the Hello message. | 2014-03-10 16:29:53 OEC FAST Data: Sending the Logon message. | 2014-03-10 16:29:53 Open E Cry FIX/FAST: Connected to the market data server. | 2014-03-10 16:29:53 Open E Cry FIX/FAST: Connected. | 2014-03-10 16:29:53 SC Market Stats: Disconnected from the server. | 2014-03-10 16:29:53 Open E Cry FIX/FAST - Starting real-time market data updates for: FDAXH4 | 2014-03-10 16:29:53 HD Request # 22 - Downloading Intraday chart data for FDAXH4 to the file FDAXH4.scid. Service: oec | 2014-03-10 16:29:53 HD Request # 22 - Download start Date-Time: 2014-03-10 16:29:47.0 | 2014-03-10 16:29:53 HD Request # 22 - Using server: ds4.sierracharts.com port 10149 | 2014-03-10 16:29:53 Open E Cry FIX/FAST - Starting real-time market data updates for: FESXH4 | 2014-03-10 16:29:53 SC Market Stats - Starting real-time market data updates for: TICK-NYSE | 2014-03-10 16:29:53 SC Market Stats: Connecting to the server ds3.sierracharts.com. Port 443 | 2014-03-10 16:29:53 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-10 16:29:53 Open E Cry FIX/FAST - Starting real-time market data updates for: ESH4 | 2014-03-10 16:29:53 Open E Cry FIX/FAST - Starting real-time market data updates for: YMH4 | 2014-03-10 16:29:53 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-10 16:29:53 The network socket is connected. | 2014-03-10 16:29:54 HD Request # 22 - Sending historical data logon request message. | 2014-03-10 16:29:54 The network socket is connected. | 2014-03-10 16:29:54 SC Market Stats: Connected to server. | 2014-03-10 16:29:54 SC Market Stats: Sending logon request message. | 2014-03-10 16:29:54 HD Request # 22 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 15:29:47. Record interval: 0 | 2014-03-10 16:29:54 SC Market Stats Server Info - Server Name: . Server Version: . Provider Name: . | 2014-03-10 16:29:54 SC Market Stats - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-10 16:29:54 SC Market Stats - Successfully connected. | 2014-03-10 16:29:54 SC Market Stats - Restarting real-time data updates for symbol: TICK-NYSE | 2014-03-10 16:29:54 HD Request # 22 - Decompressing data. | 2014-03-10 16:29:54 HD Request # 22 - Receiving Intraday data for FDAXH4 starting at 2014-03-10 16:29:47 | 2014-03-10 16:29:54 HD Request # 22 - Timestamp of first Intraday data file record written: 2014-03-10 16:29:47 | 2014-03-10 16:29:54 The network socket for historical data has been closed. | 2014-03-10 16:29:54 HD Request # 22 - Received 29 records from 2014-03-10 16:29:47 to 2014-03-10 16:29:55 (8.0 seconds) and wrote 27 records for FDAXH4 | 2014-03-10 16:29:54 HD Request # 22 - Intraday download COMPLETE for FDAXH4 | 2014-03-10 16:29:54 Real-time Intraday chart data file updates started for FDAXH4 | 2014-03-10 16:29:54 HD Request # 23 - Downloading Intraday chart data for FESXH4 to the file FESXH4.scid. Service: oec | 2014-03-10 16:29:54 HD Request # 23 - Download start Date-Time: 2014-03-10 16:29:44.0 | 2014-03-10 16:29:54 HD Request # 23 - Using server: ds5.sierracharts.com port 10149 | 2014-03-10 16:29:54 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-10 16:29:54 The network socket is connected. | 2014-03-10 16:29:54 HD Request # 23 - Sending historical data logon request message. | 2014-03-10 16:29:54 HD Request # 23 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 15:29:44. Record interval: 0 | 2014-03-10 16:29:54 HD Request # 23 - Decompressing data. | 2014-03-10 16:29:54 HD Request # 23 - Receiving Intraday data for FESXH4 starting at 2014-03-10 16:29:44 | 2014-03-10 16:29:54 HD Request # 23 - Timestamp of first Intraday data file record written: 2014-03-10 16:29:51 | 2014-03-10 16:29:54 The network socket for historical data has been closed. | 2014-03-10 16:29:54 HD Request # 23 - Received 6 records from 2014-03-10 16:29:44 to 2014-03-10 16:29:55 (11.0 seconds) and wrote 5 records for FESXH4 | 2014-03-10 16:29:54 HD Request # 23 - Intraday download COMPLETE for FESXH4 | 2014-03-10 16:29:54 Real-time Intraday chart data file updates started for FESXH4 | 2014-03-10 16:29:54 HD Request # 24 - Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-03-10 16:29:54 HD Request # 24 - Download start Date-Time: 2014-03-10 16:29:57.0 | 2014-03-10 16:29:54 HD Request # 24 - Using server: ds4.sierracharts.com port 10149 | 2014-03-10 16:29:54 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-03-10 16:29:54 The network socket is connected. | 2014-03-10 16:29:55 HD Request # 24 - Sending historical data logon request message. | 2014-03-10 16:29:55 HD Request # 24 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 15:29:57. Record interval: 0 | 2014-03-10 16:29:55 HD Request # 24 - Decompressing data. | 2014-03-10 16:29:55 HD Request # 24 - Receiving Intraday data for TICK-NYSE starting at 2014-03-10 16:29:57 | 2014-03-10 16:29:55 HD Request # 24 - Timestamp of first Intraday data file record written: 2014-03-10 16:29:58 | 2014-03-10 16:29:55 The network socket for historical data has been closed. | 2014-03-10 16:29:55 HD Request # 24 - Received 2 records from 2014-03-10 16:29:57 to 2014-03-10 16:29:58 (1.0 seconds) and wrote 1 record for TICK-NYSE | 2014-03-10 16:29:55 Added 3 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2014-03-10 16:29:55 HD Request # 24 - Intraday download COMPLETE for TICK-NYSE | 2014-03-10 16:29:55 Real-time Intraday chart data file updates started for TICK-NYSE | 2014-03-10 16:29:55 HD Request # 25 - Downloading Intraday chart data for ESH4 to the file ESH4.scid. Service: oec | 2014-03-10 16:29:55 HD Request # 25 - Download start Date-Time: 2014-03-10 16:29:48.0 | 2014-03-10 16:29:55 HD Request # 25 - Using server: ds3.sierracharts.com port 10149 | 2014-03-10 16:29:55 Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-03-10 16:29:55 The network socket is connected. | 2014-03-10 16:29:55 HD Request # 25 - Sending historical data logon request message. | 2014-03-10 16:29:55 HD Request # 25 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 15:29:48. Record interval: 0 | 2014-03-10 16:29:55 HD Request # 25 - Decompressing data. | 2014-03-10 16:29:55 HD Request # 25 - Receiving Intraday data for ESH4 starting at 2014-03-10 16:29:48 | 2014-03-10 16:29:55 HD Request # 25 - Timestamp of first Intraday data file record written: 2014-03-10 16:29:48 | 2014-03-10 16:29:55 The network socket for historical data has been closed. | 2014-03-10 16:29:55 HD Request # 25 - Received 58 records from 2014-03-10 16:29:48 to 2014-03-10 16:29:58 (10.0 seconds) and wrote 56 records for ESH4 | 2014-03-10 16:29:55 HD Request # 25 - Intraday download COMPLETE for ESH4 | 2014-03-10 16:29:55 Real-time Intraday chart data file updates started for ESH4 | 2014-03-10 16:29:55 HD Request # 26 - Downloading Intraday chart data for YMH4 to the file YMH4.scid. Service: oec | 2014-03-10 16:29:55 HD Request # 26 - Download start Date-Time: 2014-03-10 16:29:49.0 | 2014-03-10 16:29:55 HD Request # 26 - Using server: ds5.sierracharts.com port 10149 | 2014-03-10 16:29:55 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-03-10 16:29:55 The network socket is connected. | 2014-03-10 16:29:56 HD Request # 26 - Sending historical data logon request message. | 2014-03-10 16:29:56 HD Request # 26 - Requesting Intraday data. Max. days to return: 1095. Start Date-Time: 2014-03-10 15:29:49. Record interval: 0 | 2014-03-10 16:29:56 HD Request # 26 - Decompressing data. | 2014-03-10 16:29:56 HD Request # 26 - Receiving Intraday data for YMH4 starting at 2014-03-10 16:29:49 | 2014-03-10 16:29:56 HD Request # 26 - Timestamp of first Intraday data file record written: 2014-03-10 16:29:49 | 2014-03-10 16:29:56 The network socket for historical data has been closed. | 2014-03-10 16:29:56 HD Request # 26 - Received 14 records from 2014-03-10 16:29:49 to 2014-03-10 16:29:57 (8.0 seconds) and wrote 13 records for YMH4 | 2014-03-10 16:29:56 HD Request # 26 - Intraday download COMPLETE for YMH4 | 2014-03-10 16:29:56 Real-time Intraday chart data file updates started for YMH4 | 2014-03-10 16:29:56 Requesting market depth updates for: ESH4 if supported. | 2014-03-10 16:29:58 Requesting market depth updates for: FDAXH4 if supported. | 2014-03-10 16:29:58 Requesting market depth updates for: FESXH4 if supported. | 2014-03-10 16:29:58 Requesting market depth updates for: YMH4 if supported. | 2014-03-10 16:29:58 Open E Cry FIX/FAST: Received position acknowledgment message. Request Result: 2. Request Status: 1 | 2014-03-10 16:30:08 |
[2014-03-10 16:08:13] |
We did not see a reconnection problem in the last log you posted. In the first log, we see the familiar pattern we have been seeing: OEC FIX Trading: Sending the Logon message. | 2014-03-10 14:53:06 Connection timed out. Will disconnect and retry. | 2014-03-10 14:54:05 OEC knows about the problem and we expect this will be resolved soon. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-14 19:25:09] |
stevensinfinity - Posts: 8 |
Hey doctor.scalp, I am sorry to hear about your issues with OEC disconnectivity, hopefully they've been correct by now. I am a broker with Infinity Futures and understand the frustration customers can face. It's a shame, because Sierra is such an excellent charting package. With that being said, if you're still having issues our Infinity AT platform works extremely well with Sierra Charts and I more than welcome you guys to try a demo. Feel free to use this link: http://www.infinityfutures.com/practiceaccount.aspx?ref=shae I'm also more than happy to answer any questions you may have. Feel free to contact me at s.haen@infinityfutures.com or by phone at (312) 373-6224. -Stevens Haen |
