Date/Time: Tue, 29 Sep 2026 15:36:53 +0000
[Programming Help] - Cannot get Price Labels on DRAWING_RECTANGLE_EXT_HIGHLIGHT
View Count: 1428
[2021-05-03 06:28:53]
User719512 - Posts: 490
I cannot seem to get Price Labels on DRAWING_RECTANGLE_EXT_HIGHLIGHT drawings. Best as I can tell, my code matches what the UI would show if I drew the same rectangle manually. Below is some sample code that draws a rectangle, but is missing price labels for the BeginValue and EndValue inputs.
Any idea why?
Thanks,
Kory
#include "sierrachart.h"
SCDLLName("kg_Kory_Sandbox")
int AddRectangleHighlight(SCStudyInterfaceRef sc, float beginValue, float endValue, int index, COLORREF PrimaryColor, COLORREF SecondaryColor, int width)
  // Draw a rectangle highlight
  int lineNumber = 0;
  s_UseTool Tool;
Tool.Clear();
  Tool.ChartNumber = sc.ChartNumber;
Tool.Region = sc.GraphRegion;
  Tool.DrawingType = DRAWING_RECTANGLE_EXT_HIGHLIGHT;
  //Tool.DrawingType = DRAWING_RECTANGLEHIGHLIGHT;
  Tool.BeginIndex = index;
  Tool.EndIndex = index+0;
  Tool.BeginValue = beginValue;
  Tool.EndValue = endValue;
  Tool.Color = PrimaryColor;
  Tool.LineWidth = width; // To see the outline this must be 1 or greater.
  Tool.SecondaryColor = SecondaryColor;
  Tool.TransparencyLevel = 80;
  //Tool.AddMethod = UTAM_ADD_ALWAYS;
  Tool.LineNumber = 0xDEADBEEF;
Tool.AddMethod = UTAM_ADD_OR_ADJUST;
  Tool.TextAlignment = DT_RIGHT;
  // WHY DOESN'T THIS SHOW LABELS??????
  Tool.ShowLabelsAtEnd = 1;
  Tool.ShowLabels = 1;
  Tool.CenterPriceLabels = 1;
  Tool.AddAsUserDrawnDrawing = 0;
  int ret = sc.UseTool(Tool);
  lineNumber = Tool.LineNumber; // Remember line number which has been automatically set
return lineNumber;
// kg_Kory_Sandbox
SCSFExport scsf_kg_Kory_Sandbox(SCStudyInterfaceRef sc)
if (sc.SetDefaults)
sc.GraphName = "kg_Kory_Sandbox";
sc.AutoLoop = 1;
    sc.DrawZeros = 0;
sc.GraphRegion = 0;
sc.DrawStudyUnderneathMainPriceGraph = 0;
return;
  if (sc.Index == sc.ArraySize - 100 && sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED) {
    AddRectangleHighlight(sc, sc.High[sc.Index]+10, sc.Low[sc.Index]-10, sc.Index, RGB(210,210,0), RGB(0,210,210), 1);
[2021-05-03 12:37:15]
User907968 - Posts: 884
Try using 'ShowPrice' - Using Drawing Tools From an Advanced Custom Study: s_UseTool::ShowPrice
[2021-05-03 16:49:44]
Thank you for that. I try really hard to investigate and research things before asking questions, and not sure how I missed this, but that was exactly it.
THANK YOU.
I am glad this was something trivial, and I just missed that.
Date Time Of Last Edit: 2021-05-03 21:45:25
