Date/Time: Sat, 04 Jul 2026 20:15:28 +0000
Sending info on entry orders and closed trades for AOS running in another Sieera chart
View Count: 660
[2021-05-02 10:43:50]
User39949 - Posts: 25
Does sierra chart allow forwarding of information about executed, closed trades and entry orders to another installation of sieera chart registered to another username? And how can this information be populated into the AOS parameter variables that will run in this remote sierra chart installation?In the documentation, I read about assigning an order to another trading account, but there is a condition that these must be trading accounts that are available under the username that is used to log in to the trading service. Does this probably mean that it will not be possible to copy trading orders to another remote siera chart in which a different live trading account is logged in than the one from which these orders will be copied?
[2021-05-02 20:48:30]
John - SC Support - Posts: 47017
There is not a way to do what you are asking for in terms of live trades.
But, if you are interested, you can share the information between accounts as part of the Simulated Futures Trading Service. Refer to the information here:
