Date/Time: Tue, 25 Feb 2025 21:56:39 +0000
Check studies/charts dependencies
View Count: 477
[2021-05-01 16:17:01] |
Miquel Malaga - Posts: 5 |
Is there a way to check if a study has other studies using it? Or if any chart is using studies from current chart? |
[2021-05-02 20:22:29] |
John - SC Support - Posts: 38171 |
There really is not an easy way to see this. For some studies that will require a recalculation of another chart, you can see some information in the Message Log. Refer to the following: Chart Studies: References to Other Charts and Tagging For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
