Date/Time: Tue, 25 Feb 2025 22:00:24 +0000
Just switched from Sierra Pkg 5 to 12, CQG Data to Denali - seeing [M] and [C]
View Count: 522
[2021-05-01 14:55:20] |
User656492 - Posts: 146 |
I'm seeing both [C] and [M] on my charts. Does this mean I'm paying for 2 data feeds? Does it mean I've set something up incorrectly? Thanks for the support! |
[2021-05-02 20:17:37] |
John - SC Support - Posts: 38171 |
Not at all. The [M] means that you are getting the data from us. Refer to the information towards the end of this section of the documentation: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services The [C] gives you information about what kind of Continuous Futures Contract you have setup for that symbol. Refer to the following: Continuous Futures Contract Charts: Text Indicator Description Table For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
