Date/Time: Mon, 25 Nov 2024 21:56:46 +0000
TPO study and market statistics e.g. USDX
View Count: 1105
[2014-03-10 10:11:30]
BJV - Posts: 29
Hi SC, can the TPO study be applied to USDX? If yes, is it as per normal instructions..thanks
[2014-03-10 16:26:07]
Yes. This will work. You probably will need to set the Letter/Block Price Increment in Ticks to a higher value than 1.
