Date/Time: Thu, 10 Sep 2026 05:58:20 +0000
SierraCharts resolution just changed to Tiny size, what happened?>
View Count: 909
[2021-05-01 13:42:44]
HeyUgly - Posts: 280
restarted Sierra, booted up
and bam, its is super tiny size, something happened.
even if i pull the charts out, all resolution, fonts, charts the whole application is extremely "minimized" in overall function. pic attached. please help fix. i did nothing but reboot sierra
imageCapture.PNG / V - Attached On 2021-05-01 13:42:08 UTC - Size: 624.06 KB - 359 views
[2021-05-01 13:45:38]
even if i try to zoom in 200/300% all features of sierra are still tiny, this makes no sense
[2021-05-01 14:08:34]
i tried a full restart and i get the same problem , the initial launch is ok
then i open my chartbooks and the resolution goes tiny
[2021-05-01 14:12:35]
when i pull a chart out from the shrunked chartbook, everything is messed up... look at the price axis
imageCapture.PNG / V - Attached On 2021-05-01 14:12:26 UTC - Size: 53.87 KB - 344 views
[2021-05-01 14:15:45]
if i open a blank new chartbook, it seems ok. ive got hundreds of hours in building my chartbooks what could be the issue, this is a brand new pc, i ported the cb;'s over from my previous pc, is the a GPU issue? do i have to direct sierra to use new GPU?
[2021-05-01 14:24:03]
on full system reboot, it seems to have triggered, but now, all my main tool bar fonts are huge lol i cant win. any idea how to change? pics attached
imageCapture.PNG / V - Attached On 2021-05-01 14:23:49 UTC - Size: 40.95 KB - 293 views
[2021-05-01 14:39:28]
managed to get all fixed. please close for some reason all these txts were defaulting to size 27 had to go in and change them back
[2021-05-01 21:48:18]
This is caused by the operating system. Not Sierra Chart. It is the operating system interpreting the fonts sizes that you have set in Sierra Chart differently.
It is a Windows 10 behavior thing.
Date Time Of Last Edit: 2021-05-01 21:48:45
