Date/Time: Tue, 25 Feb 2025 21:59:33 +0000
Denali + CQG
View Count: 666
[2021-04-30 23:36:18] |
Andrey_s - Posts: 1 |
I've enabled CGQ routing with AMP and Denali feed, how do I put settings in place so I can trade?
[2021-05-02 19:37:08] |
John - SC Support - Posts: 38171 |
Follow these instructions to connect your Sierra Chart software to CQG: CQG Trading Platform Service: Setup Instructions Once you complete the above, then select Edit >> Translate Symbols to Current Service to change your symbols to the CQG symbols. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
