Date/Time: Tue, 25 Feb 2025 19:55:32 +0000
Monthly data fees for Acct. 37088
View Count: 500
[2021-04-30 16:31:53] |
User936216 - Posts: 1 |
Hi. I am confused and need a little help. I have paid $36 for April for the data feed service. I think maybe my need is for a cheaper service. I wonder if the $3.25 per month plan is what I need. I want "Top Book" and I trade ES, 6E, CL, GC, SI, NG, NQ, ZB, and RTY. What do you think? Are there any of these markets that I could cancel in order to bring my monthly rate down? Thank you in advance. |
[2021-04-30 17:01:50] |
John - SC Support - Posts: 38165 |
The $36.00 you paid for April is for your Sierra Chart Usage Time (Package 5 for one month). You are not getting (nor paying) for any data from us. In terms of reducing the cost of your Sierra Chart, you could change to Package 3 rather than Package 5, which will save you $10.00 per month. Just be aware of the differences between the packages and whether you need any of the features of Package 5. You will find the information on the packages here: Description of Service Packages and Pricing: Packages And one other option is to purchase multiple months up-front to reduce your "per month" charge. But it would require a larger outlay up-front. Refer to the following table for the discounted pricing by purchasing multiple months: Description of Service Packages and Pricing: Multiple Month Purchase Discount For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
