Date/Time: Tue, 25 Feb 2025 20:14:30 +0000
Point & hover for volume and candles
View Count: 681
[2021-04-30 05:05:27] |
mc8909 - Posts: 5 |
Hi, is there a way to "point & hover" on top of a volume bar and to have it display by thousands (k) & millions (m)? Also, point & hover on a candlestick chart to display the "OHLC" of each candle as well? Thanks |
[2021-04-30 13:43:54] |
John - SC Support - Posts: 38165 |
No, there is is not a Point and Hover type display. The only option is to use the Tool Values Windows, either the regular or the Compact versions with the Crosshairs. Refer to the following: Chart Drawing Tools: Tool Values Window In terms of viewing the Volume data with a suffix (K or M), if you are using the Volume study, for instance, you can set the Volume Format to Large Integer with Suffix. Refer to the following: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
