Date/Time: Tue, 25 Feb 2025 20:21:30 +0000
Monthy pivot point on intraday chart
View Count: 656
[2021-04-30 02:18:34]
User78682 - Posts: 7
Hi Support,
I have an issue while trying to add monthly pivot point on an intraday futures chart, I choose the time period type to months and time period length to 1 but still having issue loading the monthly
pivot, please help.
Thank you,
Derrik
Date Time Of Last Edit: 2021-04-30 04:10:21
imageSierra Setting.png / V - Attached On 2021-04-30 02:17:36 UTC - Size: 44.53 KB - 244 views
[2021-04-30 13:36:39]
John - SC Support - Posts: 38165
You have the Number of Days to calculate set to 1. It needs to be at least the amount of time for which you want the Pivot Points to cover (so at least 31 days to cover a full month).
Also make sure you chart has at least the same amount of data loaded.
