Date/Time: Tue, 25 Feb 2025 20:36:07 +0000
Tick Size not being respected across all charts
View Count: 691
[2021-04-29 16:47:11]
ephi144 - Posts: 54
hey SC team,
for stocks:
i am using the Chart settings dialog to set the price display and tick size for a chart to be .1 and .1 respectively.
however, that resets to .01 and .01 each time i look at new stock chart.
how can i set .1 to be default for price display and tick size as default for every stock?
[2021-04-29 17:35:27]
John - SC Support - Posts: 38165
You would need to modify the symbol settings for the symbols that are ??, ???, ???? to change the Price Display and Tick Size for stocks that are 2, 3, and 4 characters long, respectively.
Refer to the following:
Global Symbol Settings: Instructions
