Date/Time: Tue, 25 Feb 2025 20:19:05 +0000
change of the package
View Count: 585
[2021-04-29 16:21:36] |
User631370 - Posts: 5 |
Hi. I am non pro. Currently have CQG data feed, I want to change it to denali (from may) but I paid for 6 months package 5. How can I change it to higher package and just pay for these 6 months (with a discount) for software and data feed. How can I get a free demo (with non delayed quotes) of EUREX for next months? Thx for the answer Andy |
[2021-04-29 17:15:52] |
John - SC Support - Posts: 38165 |
You can change your Service Package at any time. It does not incur any costs, rather the number of days available in your Usage Time will adjust based on the difference in price between the packages. Unfortunately, the EUREX does not have a free trial/demo for the exchange. The first thing you need to do is to let your broker know that you no longer want the data from CQG as of May 1, 2021. Then, when you get going on May 1, 2021, go through the following Setup Instructions to get the Denali Exchange Data Feed setup for the EUREX data: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX Note that in the above instructions, it will walk you through changing your package. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
