Date/Time: Tue, 25 Feb 2025 20:31:52 +0000
Optimus Broker
View Count: 569
[2021-04-29 13:12:15]
jarek.skwarek - Posts: 4
Last time I use Sierra only to analize chart, but now I want start trading Dax and MiniDax. I choose Optimus Broker and I want open account and i have a few questions:
1.Actually I have 11 package + Denali+ Eurex. Will I have buy some data in Optmus?
2.Can I trade In Sierra DOM with money from Optimus Broker?
3.Will you add any commission costs or is it only on the Optimus side?
[2021-04-29 15:16:31]
John - SC Support - Posts: 38165
1. No, you already are getting the data from us, so you should not pay for it again.
2. Yes. Just make sure that you are setup with Optimus either using CQQ for your order routing. Refer to the information here:
CQG Trading Platform Service
3. You can view the effect of commissions on your trades in Sierra Chart. Refer to the following:
Global Symbol Settings: Use Global Round Turn Commission (Global Settings >> Symbol Settings)
