DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
 - Search Board |
 - Control Panel |
 - View My Posts / Threads |
 - Direct Messages
Date/Time: Tue, 04 Nov 2025 11:14:39 +0000
Problem with updating to newest SC version. Not getting s_HistoricalPriceDataRequest
View Count: 2720
|   [2021-04-29 09:55:46]     |
| norvik_ - Posts: 106 |
                Hi, support, please help. Two years ago I had created custom DTC server for broker api which used several persons. A month ago, since SerraChart changed a part of GUI, DataTradeService window, all users have problem with downloading history. Everything works fine, but client das not send this request during connection and new chart opening. I have checked all, this is not a problem client-server communication!! Coming down to 2150 SC version everything works fine with default settings. In a new one I have a strange message in a log window: "No historical data client is currently set to download historical Intraday data for...." Please, can you point, which settings in a new SC version should be done to force it REQUEST history from server!! My Data/Trade service settings is OK: see attachment. s_LogonResponse I have send back to SC contains : HistoricalPriceDataSupported = 1; OneHistoricalPriceDataRequestPerConnection = 0; Thanks in advance!  |
|   [2021-05-05 16:34:49]     |
                 . A month ago, since SerraChart changed a part of GUI, DataTradeService window, all users have problem with downloading history.  It is not related to this.What version are you currently running? We want you to update to 2253: Software Download: Fast Update See if you still have the issue and if so we will test again. Date Time Of Last Edit: 2021-05-05 16:35:13
|   [2021-05-05 16:40:38]     |
                We are releasing a new revision of 2254 (Currently pre-release) which should resolve this if there still is an outstanding issue.
