Date/Time: Tue, 25 Feb 2025 20:02:41 +0000
How to connect my account with my trading account
View Count: 531
[2021-04-29 00:44:01] |
User483289 - Posts: 1 |
Hi, How to connect my account with my trading account for real time data. When going to SC Data 8trading) it sais that my account is not connected with a live account. Im using AMP + SC + TTW Kind regards |
[2021-04-29 14:18:14] |
John - SC Support - Posts: 38165 |
AMP is no longer supporting the Sierra Chart Order Routing Service with TT. AMP should have moved your account to use CQG for order routing. If you do not have your CQG information from them, then you need to ask AMP about this. Once you have your CQG information, then you will follow the instructions at the following link to connect your Sierra Chart to CQG: CQG Trading Platform Service: Setup Instructions If you will stay connected to CQG, then open your chartbooks and select Edit >> Translate Symbols to Current Service. Otherwise, if you do NOT want to stay connected to CQG (you are not trading directly from Sierra Chart), then follow the instructions in the following link starting at Step #4: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-29 14:20:01
