Date/Time: Tue, 25 Feb 2025 20:11:32 +0000
Quick loading Continuous RTH Daily Chart
View Count: 536
[2021-04-28 22:43:27]
User290496 - Posts: 62
Denali user.
I understand that through Denali we do not have access to continuous charts, and must 'create our own' using the settings under Chart->Advanced Settings.
What I am trying to accomplish is to have a continuous Daily RTH chart. When I use the built-in method for creating the continuous chart, however, it takes an extremely long time to load ~2-3 years of data each time the chart is opened (or when you come out of replay etc.)
Right now I create the Daily chart with RTH using the method described here (using intraday data, with session time specified by user):
Chart Session Times: Day Session Only Daily Chart Bars
Chart Session Times: Creating Daily Bars with Custom Session Times
Is there some way to have this continuous RTH Daily chart not need to spend 2+ minutes each time I need to load it? Can it be pre-loaded and not refresh all the backward contracts it needs to stitch together every time in loads?
Date Time Of Last Edit: 2021-04-28 23:17:35
[2021-04-29 13:59:22]
John - SC Support - Posts: 38165
There are some things you can do, but in general, if you are wanting a lot of data, then it is going to take some time to load. Refer to the following sections on this page:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
Sections 30.11, 30.12, 30.21, 30.29
You may also want to look through section 30.48.
