Date/Time: Tue, 25 Feb 2025 20:28:49 +0000
Live Eurex trading AMP from May
View Count: 623
[2021-04-28 19:43:30] |
Woodzy76 - Posts: 9 |
I want trade Eurex from May, is it the same setup with AMP futures as my current CBOT trading, 1/ subscribe here to live Eurex data 2/ log into Sierra with CQG credentials (I prefer to create a separate Sierra instance for live exaction and keep the Denali data charting on my main instance) 3/ translate Eurex Denali symbols to CQG Do I have to set anything up at AMP end or this should work thanks |
[2021-04-28 20:55:30] |
John - SC Support - Posts: 38165 |
The only thing you need to do is to setup the Denali Exchange Data Feed for the EUREX data. To do this follow these instructions: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX There isn't anything that you should change on your local Sierra Chart setup, unless you want to. Once the data is setup, just open a chart for that symbol and off you go. With regards to AMP, we recommend just checking with them that you are setup to trade EUREX through CQG. Otherwise, there is nothing else you would need to do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
