Date/Time: Fri, 25 Sep 2026 02:52:33 +0000
[Programming Help] - Iterating through past Time and Sales
View Count: 1344
[2021-04-28 16:29:10]
User5044343 - Posts: 68
I use the below loop to flag certain time and sales transactions and draw them on a 5 second chart.
Issue is it only loops through "live" data - meaning from the time the study is added, doesn't draw anything on the chart prior to that.
I also feel its not very efficient - study shows it takes about 2400 ms.
Whats the best way to approach this?
int64_t& LastProcessedSequence = sc.GetPersistentInt64(1);
//reset the sequence number on a full recalculation so we start fresh for each full recalculation.
if (sc.IsFullRecalculation && sc.Index == 0)
LastProcessedSequence = 0;
// Get the Time and Sales
c_SCTimeAndSalesArray TimeSales;
sc.GetTimeAndSales(TimeSales);
if (TimeSales.Size() == 0)
return; // No Time and Sales data available for the symbol
//Set the initial sequence number
if (LastProcessedSequence == 0) {
LastProcessedSequence = TimeSales[TimeSales.Size() - 1].Sequence;
return;
const int threshold = Threshold.GetInt();
// Loop through the Time and Sales.
for (int TSIndex = 0; TSIndex < TimeSales.Size(); ++TSIndex)
    s_TimeAndSales Record = TimeSales[TSIndex];
    Record *= sc.RealTimePriceMultiplier;
//do not reprocess previously processed sequence numbers.
if (Record.Sequence <= LastProcessedSequence)
continue;
    LastProcessedSequence = Record.Sequence;
[2021-06-13 09:52:47]
User411647 - Posts: 22
Hey mate
can you please explain to me what exactly this code means?
