Date/Time: Tue, 25 Feb 2025 20:44:12 +0000
connect package
View Count: 399
[2021-04-28 16:28:11] |
alex22081987st - Posts: 1 |
i want connect to us equity which package i can choose. does denali has USE equity access
[2021-04-28 17:45:13] |
John - SC Support - Posts: 38165 |
To get the U.S. Equities you need to use the Sierra Chart Exchange Data Feed and activate the U.S. Equities exchange. This is separate from the Denali Exchange Data Feed, but both can work together and work with your trading service data, if that is how you are getting other data. Refer to the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
