Date/Time: Sun, 27 Sep 2026 09:28:31 +0000
Denali
View Count: 803
| [2021-04-28 12:49:42] |
| User944082 - Posts: 18 |
Hi I trade CME futures through CQG and Amp is my broker, I want to switch to Denali, tell me step by step what to do.
| [2021-04-28 15:50:43] |
| John - SC Support - Posts: 48028 |
We want to make sure we are talking about the same thing, as many people have confused the term Denali lately. Denali is the name of the Sierra Chart data feed that has data for the CME Group and EUREX. It is NOT the order routing service that we have, that is called the Sierra Chart Order Routing Service. That said, if you are wanting to use the Denali Exchange Data Feed for your data while also using CQG for order routing through AMP, then all you need to do is to follow these instructions for the CME Group data: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* And/or these instructions for the EUREX data: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX ------------ If you are wanting to use the Sierra Chart Order Routing Service instead of CQG, then you would first need to change brokers, as AMP does not support the Sierra Chart Order Routing Service. Refer to the Setup Instructions for the Sierra Chart Order Routing service and Step #2 in particular which lists a partial list of brokers: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-04-28 15:56:59] |
Ok so the first section I don't need to fill in, as I am trading with the CQG feed and routing through AMP?
| [2021-04-28 16:20:21] |
Sorry, but we do not understand your question. What section are you referring to and what do you mean you "don't need to fill in..."? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
