Date/Time: Tue, 25 Feb 2025 19:58:16 +0000
change the location of the VbP study when I use multiply same studies
View Count: 589
[2021-04-28 10:53:55] |
User61576 - Posts: 445 |
I have multiply VbP studies on my chart pls check the attached screenshots when I set one VbP for 1 day lookback and another VbP for 11 days (actually it's 5) lookback, there is an overlapping as you can see on the summarize bar is there any way to space them so they will not show on top of each other? thanks |
[2021-04-28 15:44:33] |
John - SC Support - Posts: 38165 |
Check the following inputs for your overlapping VbPs: - Volume By Price Study: Align to Far Right - Volume By Price Study: Maximum Volume Bar Width Type - Volume By Price Study: Maximum Volume Bar Width Percentage Most likely you do not have "Align to Far Right" set for both the overlapping profiles. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
