Date/Time: Tue, 25 Feb 2025 19:49:43 +0000
Cannot Download Sierra
View Count: 440
[2021-04-28 00:48:20] |
Jake W - Posts: 1 |
Hello, I cannot download the free trail software. Error message "Error saving loaded files to local system. Stopping installation. Check log. Press "install" to retry. I have been trying to do this for well over an hour cannot seem to get around it. Thank you. |
[2021-04-28 02:05:08] |
Use the ZIP installer instead. Instructions and link: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
