Date/Time: Tue, 25 Feb 2025 20:41:25 +0000
Chart Trading Lines - Customization
View Count: 671
[2021-04-27 23:12:39]
User970255 - Posts: 1
Your chart trading is superior in responsiveness to the competitors. My question is have I exhausted all my options (see attached image) for customizing the verbiage and display of the chart trading lines or is there another advanced way to make detailed changes without causing any lag issues? If so just point me in the right direction and I will figure it out myself or hire an ACSIL programmer.
The top part of the image attached is another companies trading line version as an example of a bolder more crisp display although could be bigger, followed by screenshots examples of the customizations I have done so far for Sierra including the various verbiage options.
1.) +/- auto-coloring of the text/$ amt. in bold color against black background box (especially with a white chart background)?
2.) Can we change the verbiage and specific font size? (eliminate some of the symbols "+""-" no longer needed if #1 above is implemented, eliminate "C" or replace with $, pick our own text for example "Sell" or "Buy" or a bolder bigger "S" "B" only) (change the font size of the chart-trading-line text without changing the whole chart font)
3.) Separate lengths for different order types and the open trade?
imageChartradingLine.png / V - Attached On 2021-04-27 23:11:04 UTC - Size: 158.58 KB - 225 views
[2021-04-28 14:10:02]
John - SC Support - Posts: 38165
The options for what to display in the Order line can be found starting here:
Global Trade Settings Windows: Order Quantity (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display)
Also be aware of this setting:
Chart Settings: Transparent Trade Drawings (Chart >> Chart Settings >> Trading menu)
