Date/Time: Tue, 25 Feb 2025 19:41:18 +0000
[User Discussion] - TPO Chart value area
View Count: 650
[2021-04-27 19:33:30]
PeterS - Posts: 2
I see from the documentation that i cannot use the TPO Value Area Lines study on a TPO Profile chart. With the Value area lines study you can set the Subgraph Draw Style for the Value area high and low to Transparent Fill Rectangle Top/Bottom. This setting generates the look i am tying to achieve on the TPO profile chart. Unfortunately on the TPO Profile chart this Draw Style is not available. Is it possible to add this style to the TPO profile chart or is there another way to produce the same effect that you can suggest?
[2021-04-27 20:12:15]
Ackin - Posts: 1865
Similar https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=48405
TPO value area lines for x days | Post: 253004
