Date/Time: Tue, 25 Feb 2025 19:46:44 +0000
TPO Value Area Line Study
View Count: 600
[2021-04-27 18:00:35]
User597685 - Posts: 15
Hello team,
The TPO lines chart study is giving conflicting information than that on a TPO chart. Please note: I do not have another TPO chart open in my chartbook. Tick size is the same and other settings are the same.
Thank you for your assistance.
Date Time Of Last Edit: 2021-04-27 18:11:47
image1.PNG / V - Attached On 2021-04-27 18:10:29 UTC - Size: 78.1 KB - 199 views
image222.PNG / V - Attached On 2021-04-27 18:10:41 UTC - Size: 83.24 KB - 195 views
[2021-04-27 18:25:47]
John - SC Support - Posts: 38165
Please attach a Chartbook with the two charts in it to this thread by following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2021-04-27 18:53:43]
Attached are the two files. thank you.
attachmentMNMDCandle.Cht - Attached On 2021-04-27 18:52:57 UTC - Size: 7.77 KB - 318 views
attachmentMNMDTPO.Cht - Attached On 2021-04-27 18:53:04 UTC - Size: 7.31 KB - 295 views
[2021-04-27 19:59:56]
These two chartbooks do not have the same settings for the studies. To begin with, the TPO Value Area lines study is set to .68 for the Value Area, whereas the TPO study is set to .70.
In addition, the TPO chart does not have the Evening Session whereas the Value Area Lines does, and the Value Area Lines study is NOT set to only use the Day session.
When we made all the settings exactly the same, then we got the exact same values for the Value Area Lines and the TPO studies.
[2021-04-27 20:23:48]
Thank you for taking the time to address this issue. I really appreciate your hard work.
