Date/Time: Tue, 25 Feb 2025 18:54:15 +0000
Can Not chart BITCOIN with out it glitching
View Count: 574
[2021-04-27 15:36:01]
bluejune - Posts: 34
I am using XBTUSD-BMEX for bitcoin. Only for this symbol, sierra is unusable as my charts will constantly freeze/glitch and sierra will get extremely slow.
Is this an issue for anyone else, are there any alternative symbols for bitcoin?
Any insight would be greatly appreciated. Thank you.
[2021-04-27 16:23:14]
What studies are on the chart?
What exactly do you mean by "glitch"?
Select Chart >> Chart Settings and set the Tick Size to 5. That is the first step which will improve performance at least depending upon the studies being used.
[2021-04-27 16:32:35]
Changing the tick size fixed it. Thank you.
