Date/Time: Fri, 18 Sep 2026 03:19:06 +0000
Live Denali Exchange Data Feed with AMP account
View Count: 1201
| [2021-04-27 14:33:52] |
| User153971 - Posts: 23 |
I'm very confused as to how I access the Denali Exchange Data Feed with an AMP futures account. How do I connect the AMP futures account to Sierra Chart? How do I then access the live data feed? How do I connect to the AMP futures account monthly via Sierra Chart?
| [2021-04-27 15:17:12] |
| John - SC Support - Posts: 47930 |
Sierra Chart is setup to allow the data from either us or from your trading service. If you are setup for both, then the data from us takes precedence. In terms of setting up your Sierra Chart with AMP, they should have set you up to use CQG for the order routing. If you do not have the information for CQG from them, then you need to ask them about this. Once you have the CQG information, then follow these instructions to connect your Sierra Chart software to CQG: CQG Trading Platform Service: Setup Instructions If you are NOT going to stay connected to CQG (i.e. you are going to change the Service setting to another setting such as the "Trading Evaluator") then finish the above setup to make your connection to your live, funded, trading account and then change your service back to the setting you want. Refer to the following, and note the need to connect at least once a month: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you ARE going to stay connected to CQG, then open your Chartbooks and select Edit >> Translate Symbols to Current Service to change your symbols to CQG symbols. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
