Date/Time: Tue, 25 Feb 2025 19:54:02 +0000
How to Adjust the Vertical Scale of Charts
View Count: 739
[2021-04-27 10:17:45] |
User160486 - Posts: 40 |
How do I adjust the vertical setting of my charts? I am unable to see the tops and bottoms of candles at times.
[2021-04-27 12:01:29] |
58LesPaul - Posts: 429 |
Go to the right side of chart where price is and left click then move up or down. Or right click in same area and select reset. When you right click there are multiple options for scaling.
[2021-04-27 12:10:50] |
Thank you so much for your answer. Worked perfectly.
