Date/Time: Fri, 28 Feb 2025 18:29:48 +0000
ETH/BTC
View Count: 1380
[2021-04-27 10:16:16]
User160486 - Posts: 40
Is there anyway to get the crypto pair ETH/BTC?
[2021-04-27 12:59:07]
SierraFan - Posts: 92
Here's a way to create a chart using those symbols.
How to Create High Accuracy Spread or Ratio Charts
I prefer the this method, its takes a lil extra work but worth it.
Custom Calculated Symbols
[2021-04-28 10:33:44]
Thank you for your response. On Step 5 what would I enter for the formula symbol for the ETHBTC pair?
[2021-04-28 15:25:33]
John - SC Support - Posts: 38280
You enter whatever the symbols are for the Service you are using at that moment. For example, if your Service is set to "SC Data - All Services", then you would enter "{ETHM21-CME} / {BTCM21-CME}".
[2021-05-03 08:40:59]
Thanks for the answer - what would the formula be for ETH/BTC perpetual swap futures like the ones on Bitmex?
[2021-05-03 14:15:13]
There is no way to create a perpetual symbol in the Custom Calculated Symbols. You would need to update the symbols for each new contract.
