DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
 - Search Board |
 - Control Panel |
 - View My Posts / Threads |
 - Direct Messages
Date/Time: Tue, 04 Nov 2025 11:13:53 +0000
Additional fields on SecurityDefinitionResponse not documented?
View Count: 2405
|   [2021-04-26 18:37:41]     |
| DabbaDo - Posts: 148 |
                Hello, I'm doing a C# client and I notice you've added these fields to the proto definition after ExchangeSymbol InitialMarginRequirement MaintenanceMarginRequirement Currency ContractSize OpenInterest RolloverDate IsDelayed At https://dtcprotocol.org/index.php?page=doc/DTCMessages_SymbolDiscoverySecurityDefinitionsMessages.php#Messages-SECURITY_DEFINITION_RESPONSE I only see RolloverDate documented. I know the size of all the fields except Currency, which must have some fixed width? I found it at https://dtcprotocol.org/DTC_Files/DTCProtocol.h. So this is just a comment about the documentation. :) I like what you've done here! Thank you, Dale  |
|   [2021-05-24 05:37:07]     |
                We will add these to the documentation.
