Date/Time: Fri, 25 Sep 2026 15:56:37 +0000
Rithmic Data
View Count: 907
| [2021-04-26 18:33:28] |
| User996274 - Posts: 96 |
I have rithmic data with Oneup I have an existing sc account I would like to continue with rithmic through amp I know there was an issue awhile back I prefer not to change from rithmic as my trading strategies are based on rithmic data The question is: Will you allow rithmic through amp? I was told by an amp agent that I need to have my data etc set up through sc, is that true? T Date Time Of Last Edit: 2021-04-26 18:41:03
| [2021-04-26 20:16:22] |
| John - SC Support - Posts: 48013 |
We do not give any help with regards to the existing Rithmic implementation at this point in time. But, Rithmic has been working on a new connection to Sierra Chart that has been in testing lately and therefore should be available soon. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-04-26 22:03:56] |
So if I can get rithmic from amp there should be no difference on how it connects with Oneup? (settings etc) T |
| [2021-04-27 13:46:05] |
There is going to be some difference in the settings in order to connect to the OneUp server instead of the live trading server. But other than those settings in the Data/Trade Service Settings, no there would not be any difference in the connection setup. Note that if you are going to try and use Rithmic now, you will need the files that are in this thread: Rithmic Bridge Files For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
