Date/Time: Tue, 25 Feb 2025 19:39:39 +0000
Duplicate Chart with TPO
View Count: 497
[2021-04-26 16:22:45]
User267016 - Posts: 5
I use SierraChart 2250 64-bit (37029) on Windows 10 and there seems to be a bug with the TPO study if you duplicate the chart.
Explanation:
1. A chart with TPO
2. Merge some profiles
3. Duplicate the chart
4. The merged profiles are not merged anymore on the copied chart
Maybe I have forgotten to set a specific configuration or it is really a bug.
I have uploaded two files to show the behaviour. In the first PDF you see that it works (screenshot from Merritt Black) and the other PDF shows that it does not work (my SierraChart).
attachmentWorks.pdf - Attached On 2021-04-26 16:21:33 UTC - Size: 479.24 KB - 207 views
attachmentDoes not work.pdf - Attached On 2021-04-26 16:21:45 UTC - Size: 1.38 MB - 261 views
[2021-04-27 15:05:33]
Sierra_Chart Engineering - Posts: 18564
We have looked into this and we will develop a solution for this. We do see why this happens.
This will be solved in version 2253
Date Time Of Last Edit: 2021-04-27 15:05:59
