Date/Time: Tue, 25 Feb 2025 19:44:43 +0000
Equities
View Count: 545
[2021-04-26 16:21:07] |
Yahav Dinai - Posts: 3 |
I'm currently using your denali with order routing TT for trading futures on cme. I want to add the US nasdaq/NYSE equities stock - real time feed and routing service. Can you walk me thru the process please. Thank you.
[2021-04-26 16:39:30] |
John - SC Support - Posts: 38165 |
First, we do not have a routing service for stocks. Does your broker have a method to route stocks to the exchange for you? Most likely you will need to look into a different broker for the stocks, such as Interactive Brokers. If you do have to go to a different broker just for stocks, then we recommend installing a separate installation of Sierra Chart for your stock trading. That way you will have the one broker setup for futures and the other broker for stocks. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart In terms of the data, you would just need to sign up for the Sierra Chart Exchange Data Feed and activate the U.S. Equities data. Refer to the following: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
