Date/Time: Thu, 21 Nov 2024 23:30:54 +0000
DOM scale/increment adjustment.
View Count: 2428
[2021-04-26 07:11:44] |
KylieV1618 - Posts: 67 |
Hi, I was wondering if its possible, to change the tick increment on a DOM, and combine orders into those increments. For example. Im watching binance Data on ETH.USDT, and the increments are 0.01. This makes the DOM highly erratic, so I have to compress it to see it clearly. However, this scrunches up all the numbers and makes it basically unreadable. Is there a way to change the tick increment manually, to say 0.15, or 0.25. And have the DOM aggregate all the info at those price levels. For clearer picture. I downloaded MedVed Trader to trade Binance, and its DOM can do this. But they don't offer trading on Binanace Futures. Im in the process of building my own Java tool to trade Binance futures because it seems nobody can offer this?? Are you ever going to offer trading through binance?? Please let me know Thanks Date Time Of Last Edit: 2021-04-26 07:13:16
[2021-04-27 08:29:53] |
Refer to: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) (Market Depth Combine Increment in Ticks). Be sure to read the entire section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-14 00:27:06] |
User902069 - Posts: 1 |
hello support, im facing the same issue with scaling and ticks size for Bitcoin, i followed the link above and it did help with the default columns (buy/sell) but not with the customized added columns (picture included:http://www.sierrachart.com/image.php?Image=1626222362489.png ) i also tried changing the price scale and no luck |
[2021-07-14 13:18:23] |
John - SC Support - Posts: 36203 |
The Combine Increment in Ticks only applies to the main Bid and Ask depth values. It does not impact the other columns. We have had a number of requests for this change and we have it on our list of to-do items, but we do not have any timeframe for when we can get to it.
[2023-11-16 17:10:46] |
User700792 - Posts: 4 |
Any update on this?
[2023-12-12 16:54:22] |
EloStocks - Posts: 1 |
Hello just wondering if this has been implemented yet or still in the queue?
[2024-10-24 17:51:55] |
Albu-Trading - Posts: 1 |
Hey , asking if there has been any changes made yet? Trading tickers like NQ is kind of difficult without combining the increment ticks but it makes the other columns unreadable
[2024-10-24 18:48:56] |
No changes to this yet.
