Date/Time: Tue, 25 Feb 2025 17:22:34 +0000
Denali Depth working with CQG but not Rithmic
View Count: 524
[2021-04-26 02:15:54] |
User423419 - Posts: 15 |
Hi, I'm currently using Denali depth. My heatmap and depth bars work with my cqg login, but when I try to use my rithmic login, I have no depth/heat map. Not sure if there's a setting that I need to change or what's causing the issue? Thank you |
[2021-04-26 02:42:17] |
You will need to update to the latest version of Sierra Chart to solve this. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
